Author Topic: Motor mixers  (Read 2354 times)
Tony Mattson
Motor mixers
« on: June 20, 2005, 01:22:39 AM »
Brett,
A couple of weeks you replied to my first post to PDs
In part you commented re motors:
>AH! well your talking to a "Car WindScreen Motor" specialist here :-
), refer to P.S INDUSRY, however, I would think 385's would be ok
considering you are using appropriate electronic motor controls
Does the ActionKit Marine Motor Mixer (P40) allow the motors to be
runnning in reverse to each other, ie: STB forward while Port is
reverse ?<
I have just realised that I did not reply to your question regarding
ActionKit motor mixers. Mea culpa! here's a bit of blurb from Graig
Talbot at ActionKit:
The Marine Motor Mixer project uses a microcomputer. It will control
the differential speed of twin motor units in conjunction with the
steering/rudder position, that is to say, it will slow one motor and
speed up the other during a turn. It has a specialised ABS case
45.5mm x 32mm x 20mm with onboard plug in connectors for two outer
motors, one centre motor (if used) and the steering servo,
eliminating Y leads. Will steer when stationary.
Unfortunately I omitted to ask him whether or not the mixer puts one
motor into reverse on rudder hard over and he's on holiday at the
present. However he has said that he sells quite a few of these to UK
modellers for paddler applications. Perhaps any other listers who
have used or know of this unit may wish to comment.
My impression is that this is by and large a commercially made
equivalent to the motor mixer design that Paul Jordan has posted to
the group files.
Incidentally you'll be delighted to read that I've bought a couple of
old window winder motors which I will have a good play with before
starting the next big project. What an interesting approach - huge
torque, low drain, complete with worm drive reduction gearing, and
cheap as toast! Unfortunately they're a tad big for Reliant at 1:32
scale. (Note to self - build 1:24 next time!)
cheers for now
Edward Matthews
Motor mixers
« Reply #1 on: June 20, 2005, 01:23:05 AM »
Just to confirm, YES the Action mixer is fully proportional - It will
slow one motor gradually depending on the rudder position, then when
the rudder nears full it will start running one motor in the opposite
direction - ie. one will be running forward and the other will be
running astern.
It's a lovely little unit - A friend of mine has one in his Director
class tug and it works like a dream.
Motor mixers
« Reply #2 on: June 20, 2005, 01:23:31 AM »
Hi Tony - this device sounds super - I tried a GOOGLE search to no avail - obviously you acquired one on KIWI , so
would hope the same is available in OZ
I still have not resolved PS Decoys final drive & was a little put off by the complexity our founder moderator PS's
electronic design [in our files worth a look] - I would appreciate if you could come back with the actual brand name or
supplier etc - regards Derek in Wollongong NSW
P Webster
Motor mixers
« Reply #3 on: June 20, 2005, 01:24:28 AM »
Derek,
It is always a problem here in the great land of Oz getting these bits so the best
solution I have found is to send off to GB and buy direct. Just in case you don't have
their email address it 's http://members.aol.com/actionkit/
I have yet to buy from them but if they are like most companies in the UK their delivery
will be about 7-10 days going from previous experience.
Peter Webster (from St. Albans Victoria, another bloody Mexican) :-)
