Building a steam engine
Started by Paddlemex, March 31, 2020, 05:48:16 AM
Previous topic - Next topic
Paddlemex
Haha, thanks Thomas.
But the Merc has a leak in the engine. When working on steam I noted that quite a considerable amount of steam coming from the front of the engine. The rear had no leaks (no pun intended). First I thought it might be a lack of tension of the rubber "springs", but on looking close I noticed a small gap at the front between cylinder and body. I was able to stick a 0.1mm feeler gauge in the gap. Definitely too much.
I will take closer look into this. It might be that I was a bit sloppy when drilling the holes for the cylinder trunnions and they are a bit off vertical. Should be a fixable problem.
Jurgen
Hankwilliams
Yes, but this can happen. From my experience, the first test runs of engines in as good as every case needs some improvement. This belongs to our passion!
