PS Australien Restoration
Started by michael, February 25, 2007, 08:55:55 AM
Previous topic - Next topic
rayman
Michael, don't let any one put you off. To quote John Laws "keep the dream alive" I am reposting some of your pics. can you answer the questions for me please? and what are her dimensions? L x B x Depth of hull?    regards rayman
rayman
I tried to post them together but got bogged down
rayman
And now the last 2
michael
Okay Ray, I'll see if I can answer all those questions and in order!
Q1 Yes it is the boiler room facing to the back, the timbers are for the deck either side of the boiler. I've attached a photo so you can see where the steel frames end and timbers start and what the bilge is like. The timber frames run the full width the other blocks are for extra strength for the steel beams, which the boiler sits on.
Most of the sponson brackets are there, but the rudder is long gone, I have a good shot of the rudder so wouldn't be hard to whip one up.
Q3. The wheels Diameter is 12ft therefore 12 floats on each wheel.
The gear is 2500mm in dia and 275mm wide, with 5groves for the ropes.
I'll attach photo's of the Tension pulley and gear for the engine which are both 650mm in dia.
Q4 is actually the forward hold with a hatch, and seperated down the middle for two rooms. The winch sat behind the hatchway.
Yes all the framing is angle iron.
Q5 Will attach photo's of the bow and stern
Q6 We are looking forward, so taken from the stern, there are three bulkheads. One right at the front and the other two in the engineroom.
Length is 23.4m
Width is 5m
Depth Topside- 840mm
         Timber- 730mm
She only drew 10inched when launched!
Hope that answered your questions.
thewharfonline
We should get my geography class to give you hand next week when we're up! Hands on Murray Paddler Restoration.
Hmmm might not be too geographical.
Next time I'm up though Michael I'll be there to offer my services for at least one of the days.
Looking forward to seeing her in the flesh.
rayman
Thanks Michael, I shall get back in a day or two. She looks to be in quite good condition really. Get those topsides wire brushed and a coat of paint on and it will look totally different.  rayman
Ned Feary
Michael, could you please give us a June update on the Australien? I love following the progress any paddler projects!
Thanks
          Ned.
