DUKE OF DEVONSHIRE
Started by R.G.Y., December 20, 2009, 09:34:31 AM
Previous topic - Next topic
PeeWee
Looking very good there,  i still have to smile everytime i see the beer can hull.
R.G.Y.
Ian, It was not the cans that made me smile.
Now here's a tricky job bending the rails. I ma using electric cable, after removing the insulation of course. It is a little soft but cost nothing. Geoff
ancoaster78
Just had a catch up of this thread, really fascinating build. Loving the unusual methods you use, very inovative, and the model is lookign great for it!
Looking forward to seeing it finished, esp to see how the hull plating looks painted....
Thanks for sharing the build, cheers Andy :-D
R.G.Y.
#213
Hull painting is coming as soon as the hand rails are fixed, 2 more to make. One side of the bridge rails in position (temporary). I will remove them for painting. Very up and down, the holes are different depths and the stanchions different lengths. Plan on turning up small base plates to control the height. This will enable me to elongate the holes for some adjustment if wanted. Geoff
R.G.Y.
Half hour play to day.  Made some turnbukels 8BA left & right hand thread. Brazing rod for the screws, 3/16th hexagonal brass for boady. Turn down the rod then tap, file a flat where the thrad ends, drill 1.5mm hole and part off. Sorry about the photos can't get it any better need a new camera. I have marked the left hand end with a cut. Geoff
Nice to see her progressing Geoff.
Well done!
stuart
mjt60a
yes it is,  I watch all the construction threads with interest   :)
R.G.Y.
Thanks Stuart & Mick always good to have encouragement. Unfortunately not to well last few days. Despite the rumors I do have a hart but it is playing up at the moment. So I have to rest hence the lack of progress.  Plus I have broken my left hand tap!!! Geoff
R.G.Y.
#218
Left hand tap arrived and I've finished all the left hand threads. When I was drilling the 1.8mm holes in the lathe I just use hand pressure on the tail stock, and pull the drill back out to clear swarfe, by sliding tail stock back. Saves a lot of winding. I took to big a bite and the chuck fell out and snapped the drill!!! I tried to tap after drilling a 1.7mm hole bang goes the tap!
Started the grab lines on the life boats. First I soak thin cord in weak P.V.A. and rap it around a metal bar to dry. Cut it off and it will form a natural full when stuck on the boat. Geoff
R.G.Y.
Life boats just have to paint the canvas green. Well the cooking foil this has a coat of P.V.A.so is quite strong. The weigh of each just under 1oz ( I think 35kg?) as I have said before paddlers need to be light.
The skylight with seats for the forward saloon.
Finished the turnbuckles. Unless I decide to install a mast on the boat deck, as in some early photos.
Bottom photo shows a base plate on a stanchion. Only 96 more to make. Geoff
R.G.Y.
Turnbuckles.
PeeWee
Looking good there, very nice job.   note to self, must get my lathe dusted down.
R.G.Y.
Yes Ian. use mine almost every day for something. Now do I need a mill I should have bought one a lot sooner,. Geoff
R.G.Y.
#223
The life boats just need a coat of matt varnish on the canvas.
Mast is finished, Turned the bell, belaying pins, truck and the collars on the lathe. First I measure the mast at the point the collar is required. Then drill this size a hole in a brass rod, turn down as thin as possible. Center pop for the holes using the jaws of the chuck for the spacing, drill 1.5mm holes and part off. Four required all different sizes and hole spacings. Brass wire is bent for the eyelets. Slide collars down from the top until tight, sand the mast if they don't go down far enough, drill 1.5 in to mast, fit eyelets with super glue. Fit truck to top of mast, note two 1mm holes for flag halyard. Geoff
R.G.Y.
In the photos above the pipe cleaner man is there checking on the scale. Geoff
