African paddle steamer
Started by AlanP, May 13, 2010, 06:07:55 AM
Previous topic - Next topic
AlanP
Thanks Eddy
It would be just a half, would it? seeing as you are on a stall, and me been born in Yorkshire  ;D
Alan
A half would be perfectly acceptable Alan, providing it's the top half :hehe
Seriously, I'll see if we have the drawings tomorrow and get back to you.... We wouldn't want to see a paddler languishing in a workshop due to lack of information would we?
Well I dug out the drawings for the Lulonga, and guess what, it doesn't actually show a waterline!
The only thing given on the plans is a displacement of 12Lbs, and from the ones I've seen sailing, the waterline is about three quarters of the way up the hull to the lower deck.
So it's not a definite answer, but I hope it helps a little Alan?
AlanP
Thanks for your trouble Eddy, ill work on that information.
Just ordered two of the 200 rpm motors from Kim. When I get them ill order the other gear from Motionco, after first running it past you to make sure it's the right. If that's OK
Alan
