Author Topic: Constructing a working rudder on Waverley  (Read 2260 times)
barca1au
« on: June 17, 2005, 07:32:27 PM »
Greetings from Oz!
Our plans of the Waverley show a rudder attached to the rear of the
hull by a hinge, with no visible means of controlling it. Any one
have any ideas how we can construct a working rudder? The hull
actually overhangs the rudder by a few inches so there is room to go
through the hull above the rudder and attach it that way.
Cheers
Wilf & Caroline
« Reply #1 on: June 17, 2005, 07:33:09 PM »
Hi Wilf & Caroline
if you look VERY carefully at the drawings you have of Waverley I'm sure
you'll see that there is a 'post' attached to the leading edge of the rudder
that disappears up into the hull. This will be in line with the hinges and
would have a bellcrank or similar device to actuate it via chains on the
fullsize.
Normal model practice is to attach a lever to this vertical post and couple
this to your rudder servo. If you do a trawl through some of the model shop
sites on the net you will find suppliers of all the hinges, rudder arms and
even complete rudder assemblies that you could want.
Hope this helps - if not email me privatly and I will forward you a
photo/sketch of a typical rudder installation.
