Paddlewheels/Drive Systems
Found plastic paddle wheels.
Topic: Found plastic paddle wheels. (Read 6697 times)
PaddleboxQ
Junior Member
December 15, 2021, 07:38:10 AM »
Found these on line. They are 100 mm dia and the paddle is only 10 mm wide…but I have thought about gluing two together for a wider paddle .
PaddleboxQ
Junior Member
Re: Found plastic paddle wheels.
December 15, 2021, 08:40:31 AM »
They cost me 70 cents each….probably about 0.45 P. There were also smaller ones being 70mm dia.
Walter Snowdon
December 17, 2021, 10:51:25 PM »
Hello Paddlebox Q- these have possibilities for simple models or the basics for conversion. . Where did you source them?. regards, Walter.
tonyh
December 19, 2021, 05:45:20 AM »
Walter,
I was also interested in them and had a search of the internet. I could only manage to find them on AliExpress from a Chinese manufacturer. My thoughts were to use the 7cm ones (with a couple of mm shaved off the diameter), for Vic Smeed's 'Royal Falcon' which is slowly being built. Just not sure about this seller/site and will probably stay with the plan suggested tin-plate ones.
https://www.aliexpress.com/item/1005002766487479.html?spm=a2g0o.productlist.0.0.17647c5bRx8Xgk&algo_pvid=17777f11-7f79-4783-a269-3e3e0dd19425&algo_exp_id=17777f11-7f79-4783-a269-3e3e0dd19425-2&pdp_ext_f=%7B%22sku_id%22%3A%2212000022082921814%22%7D
PaddleboxQ
Junior Member
May 22, 2023, 09:13:52 PM »
Sorry folks too many hobbies….regarding paddle wheels,I found the on Ali express as mentioned by Tony’s.
