Author Topic: Beskydy sternpaddler  (Read 11147 times)
Offline Paddlemex
« on: April 06, 2019, 03:43:55 AM »
I found this video of the rescue of a stalled cargo ship on the Elbe river in Dresden, Germany.
https://www.youtube.com/watch?v=BtiNuiZ5_8w
The interesting part is that the helping tug is a modern looking sternwheeler. The first time she appears at 2:50 and then several more times.
I googeled the name of the tug Beskydy and found some intersting information: Built in 1956 (I wasn't aware they built paddelers way into the '50s) in Chech Republic as part of a 12 ship lot. Three are said to be still existing, but I couldn't find any info on the other two.
Powered by a 550hp Skoda diesel. I found contradictory info on the number of cylinders; some say 6 others say 8.
The tug now is a museum ship available for rental and occasionally pulls cargo ships.
Looking further I found 2 videos of the working Breskydy.
Enjoy the sound:
https://www.youtube.com/watch?v=ayf127G1Wr4
https://www.youtube.com/watch?v=wLL7wBHpVng
Sounds more like a 6 cylinder to me.
Jurgen
Offline Paddlemex
Re: Beskydy sternpaddler
« Reply #1 on: April 06, 2019, 07:47:33 AM »
If you look for Beskydy tug there are lots of videos on YT. I was surprised to find that many.
Here are 2 nice ones:
https://www.youtube.com/watch?v=1NquUB8ytZY
https://www.youtube.com/watch?v=Z8kTlagU-zI
In the first one there are some views of the interior and the engine … and yes, it's a 6.
Jurgen
« Reply #2 on: April 07, 2019, 08:04:11 AM »
An interesting vessel. Until end of 1920-tis this kind of sternwheeler were build with steam engines. Similar of the diesel engine the steam engine was installed forward and with very long  pitmans inside the boat the rear paddles were driven. Unfortunalely no steam driven rear paddler in Europa is preserved.
The Hungarian Obuda shipyard until 1960 build two types of real steam driven sidewheel paddlers in great serials: The 732 class sidewheel tug and the 737 sidewheel passenger steamer of a lenght of 71 meters for use on Russian rivers. From the last types are a few protected, last 2 paddlers of this type operates until 2008 on river Lena.
« Reply #3 on: April 07, 2019, 08:18:43 AM »
May be one of this boats is again operating.
« Reply #4 on: April 07, 2019, 08:29:43 AM »
Folks.......
One of the interesting design points of the Beskydy is her stern anchor
With the length of her long blade rudder, the Designers needed to have an anchor that hopefully would not foul the rudder blade
So from this the anchor deployment hawser was made on the Starboard side........this name as we know was indeed the opposite side to which vessels tied up to.....and naturally being the port or unloading structure on of the river or sea shore and following termed as Port
So even from this, it appears that this Beskydy was also designed to have the preference to tieup Port to Port
I have not seen such an example since days of earlier sail ships
« Last Edit: April 07, 2019, 08:32:39 AM by derekwarner_decoy »
« Reply #5 on: April 07, 2019, 10:56:19 AM »
Very precise watched, dear Derek!
Regards Thomas
« Reply #6 on: April 07, 2019, 12:25:09 PM »
Whilst there is no water flow evidence by the loaded hull, from the turning circle or rate of turn, it would suggest this Beskydy may have at least one cross mounted thruster
There is also a delay by the Skipper  :nono ...in turning the rudder [at 0:26 minutes to 0:49 minutes] to Stdb when reversing the paddle wheels to astern when completing this turn to Port
https://www.youtube.com/watch?v=CMGlWmE9wrk
I suppose the other possibility is a bow rudder to allow such a turn.......the only point against this is twin rudders are usually fixed as opposed & balanced....the rate of turn would suggest the vessel did near turn in  it's own length  :clap
« Last Edit: April 07, 2019, 12:49:40 PM by derekwarner_decoy »
« Reply #7 on: April 09, 2019, 04:48:56 PM »
I have been watching as many on line Video detail as I can find on this vessel Beskydy however am none the wiser  :thinking
1. There is no evidence of a bow rudder, independent wheel  direction or an athwart hull thruster for the vessel to make a 180 degree turn
The only conclusion is the near 1/2 hull width, long rudder blade, when placed hard over in either direction creates steerage of the chosen direction, but effectively stopping and forcing the displaced water from the closeby paddle wheel backwards\
Initally I thought she was pivoting from the bow or amidships, however the more I watch the hard turn to Port,
......the vessel is effectively pivoting around the axjs of the Port paddle wheel brake effect on the Port side water [still driven as ahead] being forced out and under the port side end of the vessel in all opposite directions
The other question is "what work does she do" on the European rivers systems?
2. She appears to have some extensive midships deck hauling equipment.........she also has a number of athwart ship deck mid & aft anti fouling hawser towing bars [the ones that stop a towing rope fouling on any deck housing or equipment
There is also another Video of what appears of her main engine start up from cold & astern drive?.........noises for the first 20  seconds would not impress the Chief Engineer  :crash :41 ....
https://www.youtube.com/watch?v=axBLQRJRupQ
3. She also has what appears to be a considerable cooling water discharge stdb side fwd under the mid fwd deck accommodation block....the only thought is fwd mounted generator set/s?
So if any member can  shed any comment on this would be interesting and appreciated
« Last Edit: April 09, 2019, 05:15:04 PM by derekwarner_decoy »
« Reply #8 on: April 09, 2019, 06:44:46 PM »
"Beskydy" sounds like my old Hanomag Truck - awful noisy compared with a steam driven vessel. But back to the art of funktions: Yes, as far I know there is no bow thruster, even indepent wheel direction would give little effect at a sternwheeler. But the long rudder directly is installed after the wheels, as one can see, waterstreaming is very strong and consequently the grade of effect of the rudder position. I also suppose, that she was pivoting from the bow or may be further midships. Propulsion is dieselhydraulic not -elektric.
Offline Paddlemex
« Reply #9 on: April 10, 2019, 01:43:52 AM »
The turning is indeed amazing. As Derek says there is no evidence, not even in the slipway video, of any thruster in the hull. It seems that just the slight reverse paddeling and then again full power forward does the job. The skipper seems to know what he is doing. The guy standing at stern seems to give some signals to the skipper. Distance to the shore??
Thomas: I found that the propulsion is mechanical by a 40 m long driveshaft from the front engine to a crown and bevel gear at the paddle shaft. The crown gear is said to be 2m in diameter (in German: https://www.saechsische.de/historischer-schlepper-legt-an-3505263.html ). But then again this is the article that mentions the 8 cyl. engine, so who knows if it is correct.
Jurgen
Thomas: you have a Hanomag truck?
« Reply #10 on: April 10, 2019, 07:10:57 AM »
Hi Jurgen,
I had a Hanomag AL 28 Truck from 1986 until 2003. Together with my artist companian Waltraud we made several journeys throught Africa and western Asia. See my old postings about exploration steamer "Welf", today I add 2 posts. In 1990 - 1991 we tried to find the wreck of Baron Deckens Steamboat in the Somalian Juba river. But meanwhile the overthrow in Somalia was happened and it wasn´t still possible to visit the land. We never reached the place of Decken`s shipwrecking. But then we  travelled throught the whole continent... awesome times in every case!
« Reply #11 on: April 10, 2019, 07:33:56 AM »
From the 'Zadnokolesový remorkér Beskydy Youtube clip.....
The engine valve gear threw we as I count maybe 12 valve rods?  :a102 .....so just to make sure, and clearly yes 6 high pressure fuel pipes .....one to each cylinder....the Skoda is a 6 cylinder diesel
____________________________________
Large rudders have always interested me as early Australian river paddlers were built with "Barn Door" wide rudders capable of swinging 90 degrees to each side
« Last Edit: April 10, 2019, 03:24:14 PM by derekwarner_decoy »
Offline Paddlemex
« Reply #12 on: November 02, 2022, 05:45:59 AM »
Hello All,
I am pulling up this topic because I just saw the Beskydy in action on the Rio 2 Live Stream.
https://www.youtube.com/watch?v=2DIWc3k_iMI
The Rio 2 is a push-tug with 2 barges which travel all european rivers and canals.
On today's trip (November 1st, 2022) on the upper Elbe river in Czech republic they were helped by the Beskydy because the Rio could not fight alone against low water level and strong flow of water.
Since this is a live stream you have to be quick and scroll back to 8:15 am to see the Beskydy arrive and on 16:30 she drops the cable and returns.
Unfortunately there is no separate YT video of this.
Apart from today's paddle wheeler moment it is quite interesting to see the vast river and canal system in europe. You can travel from Hamburg to the east of Czech Republic or to Antwerp or Paris.
The Rio will continue tomorrow to Lovosice and from there take a cargo to Antwerp.
Hope its not too late and someone can still catch this modern stern paddler in action.
Jurgen
