Paddler Information
Research
Seeking info about gangway on the deck of a SS
Topic: Seeking info about gangway on the deck of a SS (Read 6244 times)
Ilhan Gokcay
Junior Member
January 15, 2019, 05:45:45 AM »
Dear friends,
I have some original drawings of a steam paddle ship. The vessel is a passenger ferry paddle steamer. There is a point on the drawings which I have diffuculties to visualise as there are not sufficient info. It's about a gangway on the deck.
On the drawings, there is a gangway shown on the deck crossing midships aft/front the paddleboxes.
I'm trying to find out, how does it look like? Is it a simple second (higher) planking on the wood deck or ?
The only cross section view does not tell much but brings up one more questions i.e. "is there a wood planking around the engine room?"
Thanks again in advance for your opinions.
Re: Seeking info about gangway on the deck of a SS
January 15, 2019, 08:45:09 AM »
These are interesting questions Ilhran.....
1. The Drawing may have a file name of ''Deck Gangway 1, 2, 3 & 4", however I suggest this is only the chosen name saved, as you see they are detailed sectional Drawings of the Vessel and do include
dimensional detail of the main deck timbers
,and snapshots of lower or Tween Deck planking
2. It is acknowledged text reference is made to ''For Detail of Gangway see Separate Plan', however if you look at the image of the vessel and her elevation Drawing,it can be seen that the only provision of hoisting is FWD however the upper and lower deck plan would preclude the storage or and movement of any Gangway
3. Whilst not shown, it would be fair to believe that deck planking on the lower deck [including engine room] would have also been planked and with similar sectioned timbers
4. Was PS 427-8 built in England for the Turkish trade?......a vessel of such size would have only plied established waterways and routes, so would these destination wharves not had or used the shore based gangways?, or my best guess is disembarking via..."
Double Chain Across & Ladder Portable
" could this be the term Ladder being a gangway?
This last point is one that other members could possibly offer greater correction or clarification
It is also of mention, that not all detail is shown in or on Drawings......the image of Hale Seyyale on the water shows a davits & a lifeboat on the FWD Stdb side which [lifeboat] is not on any Plan
There is also a cluttered out of focus detail of horizontal dark object on the FWD Stdb side paddle sponson?.....could this be a Gangway in the stored position?
PS....reading the electronic Postcard Book on Budapest and the Bosphorus, it is clear that paddler ferries were of an immense and great importance to the transportation of the populace then and still today with alternate ferries....the story of Hale - Seyyale can be translated here
http://www.sualtigazetesi.com/?p=13634
Last Edit: January 15, 2019, 03:57:43 PM by derekwarner_decoy
Ilhan Gokcay
Junior Member
January 15, 2019, 10:06:57 PM »
Hello Derek, thanks for your helpful response.
The drawings 1,2,3,4 are cut out parts of the main deck and cross section drawings, I named them myself.
Yes, PS427-8 was built in England for Turkey. It's used as passenger ferry in Bhosporus.
(There are some other drawings which shows lifeboats ob both sides.)
I suppose that this gangway is a part of the deck (raised or not I don't know or seperate than the wood deck) for the passengers to step on. But how does it look like ?
By the way, what do you mean with "plied established waterways" ? Thats not clear for me.
Ilhan
Last Edit: January 16, 2019, 01:21:54 AM by Ilhan Gokcay
January 15, 2019, 10:47:10 PM »
Ilhan
Again I see the text words '
', however I do not believe it [the gangway] would be stored athwart ships in such a vulnerable place where passengers would walk ...clearly it would have been a hazard for the very crowded passenger numbers
You could research passenger paddlers of similar age/tonnage used in England & see if you can find any images of gangways
There are video images of PS Waverley & gangways, however she is near twice the tonnage and a different build
With respect to
, I simply meant the Sayyale would berth at passenger wharf's where shore side gangways may have been used?
Interesting to see that units of measure for deck rope were also listed or recorded in
Fathoms
eg., 75 Fathoms of 7 1/2" [circumference] Tow Line
Last Edit: January 15, 2019, 10:55:45 PM by derekwarner_decoy
TailUK
January 19, 2019, 03:13:58 AM »
I think that the planked sections are areas of the main deck that form planked walkways across the width of the ship and separate the front and rear Saloons from the Engine room. You can see on the Main Deck arrangement and "Deck Gangway 2" drawing that the doors of the First Class Saloon opens into the planked area. The ends of each gangway is open to the weather and I assume that the decks in the gangways are planked to provide a "non-slip" surface for passenger entering the Saloons on the main deck and ascending the stairs to the Promanade Deck. The catwalks shown on the engine room sections are running lengthways through the engine room to provide access to the crew wishing to move between bow and stern. I'm pretty sure that this is the only area of the Main deck that is planked as the majority of the rest of that deck is taken up with the 1st and 2nd Class saloons which would have either Linoleum floors or carpets. The plan doesn't show what the deck of the Promenade is. But it could be just steel plates.
On the drawing the green line marks the gangways. The Blue square shows the water tanks shown on your first drawing.
Last Edit: January 19, 2019, 03:29:31 AM by TailUK
Ilhan Gokcay
Junior Member
March 27, 2019, 04:46:26 AM »
Dear friends,
thanks for the helpful comments.
Regarding the same ship I have another point which I need to clarify which is the constuction of bulwarks.
Unfortunately on the drawings it is not clearly shown.
My main concern is that there are no stanchions shown on any drawing. Can this be true that the bulwarks are steel plates without any support. The steering chain covers are also shown flush with the bulwarks that there is no room for stanchions.
I couldn't find any similar vessels which have such bulwarks.
Ilhan
Last Edit: March 27, 2019, 04:53:31 AM by Ilhan Gokcay
March 27, 2019, 08:21:51 AM »
Ilhan.....the vertical stanchions are there, just hidden [not shown] in these views....will mark up a drawing & re-post tonight...... Derek
_______________________
I suggest the Drawing is not a correct representation of the actual vessel construction
Stanchions or building verticals can be seen from the lower bilge area of the hull, up through to the deck level all on axis, then an another set of stanchions supporting the very top deck roof, however on a slightly altered spacing
This may be very well true, however makes no sense from a builders strength of hull perspective
It is also true for the building of a model.....the plan view nominates the stanchions covering the aft Salloon roof, and also depicts the other sets of stanchions moving FWD
The physical size of the upper set of stanchions may be marginally smaller than the lower sets, however logically they should be on axis with each other............
The steering chain is shown, however in straight runs, the chain is sometimes replaced with straight bars with tensioning chain buckles, leaving the chain to negotiate the bends in plane........
In the Aft Plan view, the text does nominate Teak Cover over Steering Rods
Last Edit: March 27, 2019, 01:01:53 PM by derekwarner_decoy
Ilhan Gokcay
Junior Member
March 27, 2019, 06:04:08 PM »
Hey Derek,
thanks for the helpful clues.
I'm making a CAD drawing and trying to be detailed and true as possible.
Ilhan
Paddler Information
Research
