Author Topic: Another Graupner Glasgow  (Read 25113 times)
Offline redpiperbob
« on: November 26, 2018, 03:05:45 AM »
Hi All
I am building it with a Graupner steam engine and boiler. Any comments would be well received.
I had some trouble with the shaft for the wheels. The indentations were in the wrong position as the gears would not mesh.
I only found this out after cutting the holes for the shaft bearings.
I had to reposition the shaft afterwards. so there are two big holes in the hull to fill.
Has anyone else had this problem.
Anyway here are some pic's.
Offline redpiperbob
Re: Another Graupner Glasgow
« Reply #1 on: November 26, 2018, 03:08:46 AM »
Here are some more pic's
Offline redpiperbob
« Reply #2 on: November 26, 2018, 03:11:28 AM »
and pics of the wheels. I have replaced the press studs in the wheels with 3mm x 10 mm srews and nuts .
The nuts are thread locked to the screws.
« Reply #3 on: November 26, 2018, 11:07:34 AM »
Looking good  :clap :clap :clap
Offline redpiperbob
« Reply #4 on: December 09, 2018, 08:55:37 PM »
Ok so I have got some more done to the Glasgow.
First the moldings of the vents were baddly bent so I made a new pair on the 3D printer.
Then I got the wheel wings fitted in the correct position.
Offline redpiperbob
« Reply #5 on: December 09, 2018, 08:58:48 PM »
I didnot like the idea of the stick on transfers for  the paddlewheel cover so I cut some thin plywood out then cut out the holes in the correct positions.
I thenfitted the steam plant in position.
Offline redpiperbob
« Reply #6 on: December 09, 2018, 09:00:39 PM »
I could then get on withthe superstructure.
« Reply #7 on: December 09, 2018, 11:17:15 PM »
 :clap :clap :clap :clap :clap :clap :clap
« Reply #8 on: December 10, 2018, 05:50:04 AM »
Looking really good Bob... Couldn't agree more about the sponson sides, so much better properly cut out as they would have been in real life!
Offline redpiperbob
« Reply #9 on: January 09, 2019, 02:29:27 AM »
Ok so thats the Glasgow finished.
Bob
