Kits & Hulls
Graupner Glasgow modification
Topic: Graupner Glasgow modification (Read 9759 times)
rob
Junior Member
April 23, 2018, 12:50:45 AM »
Well , I've been after one for years and found this one on eBay.
It looked good.
Got it home, turned it upside down and it all but fell apart, it had been painted before glueing.
rob
Junior Member
Re: Graupner Glasgow modification
April 23, 2018, 12:53:07 AM »
I was somewhat miffed I must admit, so started the rebuild after seeing this pic
rob
Junior Member
April 23, 2018, 01:02:16 AM »
If I can resize ( or someone can do it for me) you will be able to see it here.
Drive is still single motor with graupner white gears. Twin motors with chain drives might be an option later.
I have replaced all pins in the paddles with 2.5x10mm bolts and nyloc nuts.
rob
Junior Member
April 23, 2018, 01:03:36 AM »
Here is a better pic of the inspiration
April 23, 2018, 02:23:03 AM »
Are you going to build it as an armed paddler with a gun etc? It would certainly be different!
I used to have a "Glasgow" many years ago, and it was always a good sailing model - I never found the need for independent motors as it turned pretty well without, and saved a lot of expense and complexity.
rob
Junior Member
April 23, 2018, 03:06:14 AM »
Yes Eddie, with a T34/76 turret on the front as per the inspiration picture
As soon as I can get a 'so far' picture to resize I will post it , also welded deck for and aft with an armoured belt riveted over in the centre ( like a BK1124)
Last Edit: April 23, 2018, 03:08:26 AM by rob
rob
Junior Member
May 27, 2018, 06:44:34 PM »
thanks to Eddy, here are a couple of pics for your comments,
Yes the hull isn't deep enough with the scale changed to 1/16 ( I had a spare 1/16 turret laying about from a previous BK1124 build) but on the water it doesn't look too bad . . . . I'm hoping people will be too busy counting rivets to notice.
Last Edit: May 27, 2018, 08:13:21 PM by rob
May 27, 2018, 08:25:32 PM »
It's looking good to me Rob, even though there have been many Graupner Glasgows modified over the years, I've never seen one like this, so it will certainly stand out from the crowd!
I always thought the Glasgow hull could be cut at it's widest point and lengthened fairly easily to give a hull suitable for one of the Rhine paddlers...
Keep up the good work and let us know how it proceeds...
Kits & Hulls
