New project: Model of second german steamship "Courier"
3
5
Topic: New project: Model of second german steamship "Courier" (Read 47731 times)
Hankwilliams
September 07, 2017, 02:01:21 AM »
Hi friends and neighbors,
as I wrote in heading research some weeks ago, I now began a new project: Sidewheeler "Courier" of 1817. The original made the first far steamboat connection on the continent between Berlin and Hamburg.
She was working from 1817 probably to 1821. Some informations and parts of plans about this boat are preserved.
First picture shows a model in the german museum of inland navigation in Duisburg. My model will have some alterings, because after the museum model was finished some previous unknown plan fragments and documents were found. Scale is 1 : 25, which gives a lenght of 1600 mm, a breadth of 144 mm
and a depht of 90 mm. Like the original, I will installate a functionable one cylinder side lever engine with boiler.
Hankwilliams
Re: New project: Model of second german steamship "Courier"
September 11, 2017, 08:04:47 PM »
Planking of hull now is nearly finished. Next job will be to grinder and work with spatula until the surface will be fine and even.
Planking goes rather fast, as you can see, the hull is simple and box like except bow and stern.
September 13, 2017, 03:27:37 PM »
Looking good Thomas
andy
September 20, 2017, 06:11:33 AM »
Hi Thomas,
did you already calculate the possible weight of the ship? These slim hulls sometimes get some problems in weight and stability. And the windows so close to the waterline? I think, you will have to save much of weight. For example: My PD DIESSEN is 2m long and maximum 16kg ready for go. Including boiler and steam engine.
Andreas
Hankwilliams
September 22, 2017, 08:49:45 PM »
Hi Andreas,
the hull - except bow and stern - is block like. The block coefficient of the complete boat hull therefore will be approximately 0,78.
This gives a deplacement of (16 x 1,4 x 0,3 x 0,78) 5,28 litres. Not very much for a model with boiler and steamengine indeed, but sufficient.
The harder woodwork of the model now is nearly complete - I will post some pictures in the evening.
Next job will be to paint the hull in and outside with resin, G 4 by Voss Chemie gives excellent results. This one component resin get deep into the wood, it hardens the wood and will result a watertight and very stabile casco.
Hankwilliams
September 23, 2017, 01:36:44 AM »
some pictures of progress.
Unfortunately no picture of the original boat is preserved. The paddleboxes I made different from my plan semi - round, this seems more paddlesteamer like, I think.
September 23, 2017, 12:38:15 PM »
Looking real good Thomas.
Hankwilliams
September 25, 2017, 05:55:39 AM »
Thanks Damian,
at weekend I painted the hull in- and outside with G 4 resin. The wood got now very hard and only superficial work like polishing for preparing the paint is necessary.
Show a further picture of my "Prinz Carl" in 1 : 25, first iron built steamship in Germany of 1834, which I made 19 years ago. "Prinz Carl" also worked between Berlin and Hamburg.
September 25, 2017, 07:18:09 AM »
That is an interesting image of the Prinz Carl you have Thomas.....
The vessel appears to be
lightly rigged
for emergency fore & aft sails......were the German requirements/laws such that these
new fangeled steam engined
vessels must carry sail for emergency use?.....
I understand the British Board of Trade made the similar requirements up until the turn of the Century...however have never studied or researched this
Hankwilliams
Reply #9 on:
September 28, 2017, 06:06:22 PM »
Yes Derek, these boats were lightly rigged for the long distance run between Berlin - Hamburg and retour. One must consider, that the rivers in this time were in natural condition without locks and dams.
The "Prinz Carl" in difference of the much former "Courier" wasn`t a reliable boat because of her insufficient sidelever engine. After a few trips the engine was removed and the vessel became a towed boat.
Hankwilliams
Reply #10 on:
September 29, 2017, 08:31:19 AM »
I paint the hull in the meantime. Next job will be the windows. The windows sprouts are difficult, probably I will use wire netting.
Reply #11 on:
September 29, 2017, 10:10:00 AM »
You build
at such speed Thomas
You mentioned ~~+ 5kg as displacement ......for interest what is the hull weight in it's current state....and do you have a water pond close by to confirm her draft?.......or so establish what weight you can add?
I ask this as my steam engine plant is ....6277gm
...[and the base plate for the plant is 2.5mm thick aluminium sheet with pressed sides]
So I still need the hull weight [for a 1.5m long hull] & say 750gm of boiler feed water].......maybe I am looking at ~~ 12+ kg?
Last Edit: September 29, 2017, 10:25:47 AM by derekwarner_decoy
Hankwilliams
Reply #12 on:
September 29, 2017, 10:16:57 PM »
the deplacement will be no problem, engine (I will use cylinder and crankshaft of Regner 12/36) and boiler will have a weight of not more than 2200 gramm.
Now the hull weight must be below 1 kg, our old balance don`t react until now.
See the picture of my "Tachtalia" with two small oscillating engines and one boiler. This model I made with GRP Hull, lenght is 1500 mm, hull breadth ca. 190 mm. Draft is only 25 mm!
Hankwilliams
Reply #13 on:
October 05, 2017, 08:55:19 PM »
Making of windows with wire netting and wood fillets. For my opinion the result is quite sufficient. May be, with photo etched brass the windows would be still more fine, but with far more expense.
Derek - weight of the whole model is now 1,7 kg.
Hankwilliams
Reply #14 on:
October 05, 2017, 08:58:44 PM »
Here the pictures
3
5
