Author Topic: Murray River Paddle Steamer.  (Read 21264 times)
PeteH
Re: Murray River Paddle Steamer.
« Reply #30 on: May 06, 2016, 05:54:57 PM »
Wow Tony - incredibly fast progress.  With the engine/boiler in the hull does not seem quite as clunky now.  Great work
Offline Tony Bird
« Reply #31 on: May 08, 2016, 02:11:25 AM »
I have been into town to get some R/C gear from a model shop and on returning home set about fitting it into the hull.  As for the moment the R/C will be for rudder only and space is a bit limited so a box for the R/C was made.
All the R/C gear fits in the box, which will give limited protection from water.
The weight of the batteries etc. will replace some of the lead ballast, the R/C box is held into the hull with a couple of brackets.
The rudder fitted.
The model is now about ready for checking out.  A tank for the waste oil still has to be made and a box to transport the will also have to be made.  So with a bit of luck and good weather it shouldn't be long before the model has its maiden voyage.
Regards Tony.
Offline Tony Bird
« Reply #32 on: May 09, 2016, 06:03:47 PM »
In theory the model is ready for its maiden voyage.  A tank for the separated oil has been made and fitted, it will be empted using a syringe and the hull has been re- ballasted to compensate for the weight of the R/C.  I am in the process of making a box to transport the model in.
Regards Tony.
« Reply #33 on: May 09, 2016, 09:50:48 PM »
A terrific model Tony.  :bravo :bravo
