General
Chat & Off Topic Stuff
Building a river boat
10
11
12
13
14
Topic: Building a river boat (Read 97906 times)
victor vector
Re: Building a river boat
Reply #150 on:
March 11, 2016, 03:04:22 PM »
I think your`e right Damien , its all a little risky I think......
Reply #151 on:
March 11, 2016, 09:41:03 PM »
How many are you using? and what about a dome topped vent above each to get air flow and thus cooling.
victor vector
Reply #152 on:
March 11, 2016, 11:29:28 PM »
Good question Damien ....to be honest , I don`t know how many ?
I had thought of mushroom vents , over each light fitting perhaps .....just like you suggest.
Maybe its just safer to use strip led side lighting ?
Reply #153 on:
March 12, 2016, 10:50:06 PM »
It may be self defeating with all that foam for heat protection to have heat producers in the ceiling.
victor vector
Reply #154 on:
March 13, 2016, 05:06:10 AM »
Can lights idea scrapped I think ,
Thanks Damien.
victor vector
Reply #155 on:
March 14, 2016, 04:18:42 PM »
Fitting ceiling panels .
Each panel is approx 4 x 4 ft .
96 square ft. Some fiddly trim work to do now.
Up and down the ladder ...measure ....cut .....trial fit .......adjust if necessary ....slow and a little tedious .
Last Edit: March 16, 2016, 10:06:09 PM by victor vector
victor vector
Reply #156 on:
March 27, 2016, 11:17:19 AM »
I have completed my rear deck railing .
50 x 50 mm ( 2 x 2 inch ) treated pine.
The top rail has a 19 x 90 mm (3/4 x 4 inch) hardwood cap epoxy glued on top.
The top rail is seated in a shallow notch cut into the rear post.
Post anchored with strong steel brackets.
A single 100 mm stainless screw holds the upright in place while the epoxy glue sets.
The entire structure feels sturdy and safe , but heavy steel brackets will be added .
As seen from the rear deck.
Canvas was glued around timber battens and fixed in place with stainless steel cup washers over another larger washer. All screwed down with heavy gauge stainless steel screws.
Last Edit: March 27, 2016, 12:14:19 PM by victor vector
Reply #157 on:
March 27, 2016, 02:10:51 PM »
Really coming together now
I bought a pair of these for above dark spots perhaps may suit your needs the ones I have now not quite bright enough have no heat output.
Lots to choose from on ebay.
http://www.ebay.com.au/itm/281449817892?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
victor vector
Reply #158 on:
March 27, 2016, 04:45:10 PM »
Thanks Damien ,
They look like they may well do the job .
victor vector
Reply #159 on:
April 03, 2016, 02:48:34 PM »
The time is approaching when I need to run some electrical cable .
I was considering running some cable over my ceiling panels ( polystyrene ).
Has anyone here any experience with this phenomena or even heard of this before ?
Its a new one to me ?
PVC cable insulation and polystyrene insulation
The remains of electrical cables lying on polystyrene insulation board
Damage caused by the innocuous positioning of electrical cables upon polystyrene
http://www.esfrs.org/black-museum/all-the-black-museum-cases/pvc-cable-insulation-and-polystyrene-insulation/
http://www.generalcable.co.nz/getattachment/0ebda90b-b4f8-43ae-b622-c9280295116b/PVC-Cables-in-Contact-with-Polystyrene-or-Bitumen.aspx
victor vector
Reply #160 on:
April 06, 2016, 10:54:23 AM »
It`s actually raining here today !
So , I moved inside and started on some finish trim work in the front cabin.
victor vector
Reply #161 on:
April 18, 2016, 12:45:59 PM »
Hello all ,
I did some more recycling today.
Found these in my travels to town today and could not pass them by.
Dirt cheap and the lead light glass was in perfect condition.
The only down side to this was the " ugly eighties " router work.
I took out the glass and cut away the entire ugliness with a straight cut router bit.
The new cut became the new rebate for the glazing bead , so the inside face of the door was turned around to become the outside of the door.
The back showing the rebate I cut for the glazing bead.
And here two before and after pictures.
These measure 860 mm high x 480 mm wide and will be a good size for some internal cabin cabinets.
I like giving old , no longer wanted things a new life.
Last Edit: April 18, 2016, 12:51:17 PM by victor vector
Reply #162 on:
April 18, 2016, 01:19:20 PM »
Your boat but I liked the original routed look each to their own ideas.
victor vector
Reply #163 on:
April 18, 2016, 01:32:39 PM »
But .......
It dates that door Damian ......sooooo ....1980s ?
This is the original federation look ....plain square edges.
Reply #164 on:
April 18, 2016, 03:35:08 PM »
Fair enough.
10
11
12
13
14
General
