Author Topic: 3 Hull Glasgow  (Read 3540 times)
Offline scotfriend
3 Hull Glasgow
« on: October 15, 2014, 03:41:49 AM »
Hi folks,
i have now started my newest project, a paddle tug with the hull made out of three. Sounds strange and it is. The middle section of the Glasgow hull is straight this helps a lot in this project, the straight section is 80mm fwd and aft of the driveshaft. I have two hull's from ship wreck's and a brand new one, the idea is cut of the bow from hull no.1 and stern of no.2 and use the middle part of the new hull and then fix them together. The tug will also have bigger wheel's created from two set of Glasgow wheel's. Length over all will be 4 feet 4 inch long and 1 feet 8 inch wide. The main layout is based on the Tug Anglia.
I keep you updated, regards Hans.
Re: 3 Hull Glasgow
« Reply #1 on: October 15, 2014, 03:48:18 AM »
That sounds interesting Hans, I'll look forward to seeing pictures of it as you progress...
Offline the bombus
Re: 3 Hull Glasgow
« Reply #2 on: October 15, 2014, 07:21:30 AM »
more more more ,sounds nice ,pictures,
gr from The Bombus
and maybe it will work
