Author Topic: Ballast weight  (Read 7910 times)
Offline Lord Nelson
Ballast weight
« on: September 11, 2014, 08:17:00 PM »
HMS Volcano from Marks Model Bits. Length 95cm. Beam 17 cm.Can anyone please give me a ballpark figure for the all up weight of this completed model, I am particularly interested to know how much ballast would be needed. I appreciate an accurate estimate is not possible.
Thanks, Terry
Re: Ballast weight
« Reply #1 on: September 11, 2014, 09:12:12 PM »
Hi PD's...... :crash.... may be best ....[your Honourable Lord Nelson] to nominate which version of HMS Volcano you discuss  :coffee................. Derek
____________________________________________________
From Wikipedia,
Five ships of the Royal Navy have borne the name HMS Volcano. Two more were planned, but never completed:
HMS Volcano was an 8-gun fireship purchased in 1778 and sold in 1781.
HMS Volcano was an 8-gun fireship purchased in 1780 and sold in 1784.
HMS Volcano was an 8-gun bomb vessel purchased in 1797 and sold in 1810.
HMS Volcano was originally a 16-gun sloop named HMS Heron. She was reclassified as a bomb vessel in 1810 and renamed HMS Volcano. She was sold in 1816.
HMS Volcano was to have been an 8-gun bomb vessel. She was ordered in 1819 and cancelled in 1831.
HMS Volcano was a wooden paddle sloop launched in 1836. She became a floating factory in 1862 and was broken up in 1894.
HMS Volcano was to have been a W-class destroyer. She was cancelled in 1918.
HMS Volcano was a World War 2 land-based training establishment at Holmrook Hall, Cumbria, specialising in explosives
Offline Lord Nelson
Re: Ballast weight
« Reply #2 on: September 11, 2014, 09:32:28 PM »
The hull I am considering is Paddle tug HMS Volcano (renamed HMS Volatile in 1919). I was hoping that the basic hull dimensions given would be enough info to answer my query. PD's I bow to your superior knowledge, and only ask for a rough estimate.
Lordly greetings.
Offline Brian Gates
Re: Ballast weight
« Reply #3 on: September 12, 2014, 12:57:08 AM »
Hi Terry
Dromedary class tugs displaced about 700 tons and were 144' BP, so as your model is 1:48 scale we could try the cube rule.  Assuming the hull is to scale (which should be a reasonable assumption from a John R Haynes mould) she should displace 700 * 1000 /(48*48*48) kg, so somewhere between 6 and 6.5 kg seems reasonable.  Probably toward the lower end if you are planning on a freshwater boat.
Brian
Offline Lord Nelson
Re: Ballast weight
« Reply #4 on: September 12, 2014, 01:09:26 AM »
Thanks Brian, exactly what I needed to know.
