Author Topic: PS Bellarine  (Read 39306 times)
Offline Doonie
Re: PS Bellarine
« Reply #15 on: January 20, 2014, 12:40:03 PM »
and
« Last Edit: January 20, 2014, 12:55:48 PM by Doonie »
Offline Doonie
Re: PS Bellarine
« Reply #16 on: January 20, 2014, 12:45:27 PM »
and
« Last Edit: January 20, 2014, 12:51:35 PM by Doonie »
Offline Doonie
Re: PS Bellarine
« Reply #17 on: January 20, 2014, 12:47:09 PM »
and
Offline Doonie
Re: PS Bellarine
« Reply #18 on: January 20, 2014, 12:49:09 PM »
and last but not least,
Cheers,
Doonie
Sorry bout all the posts.   I couldn't figure out how to post the pics.
Re: PS Bellarine
« Reply #19 on: January 20, 2014, 01:27:46 PM »
Well hullo PD's.......... :whistle ...that was a quick conversion from a paddle wheeler to a high speed racing hull?  :oops
The subject hull is very interesting  :hammer ....but a little away from what I expected........ :squareone ...you could copy & paste into a new thread created by yourself......
It is important  :gift  to keep ....eg., a thread on PS Bellarine closely associated to that vessel
BTW that rudder :shhh...will it have enough surface area to steer that electronically powered monster speed boat?.........Derek
« Last Edit: January 20, 2014, 01:32:19 PM by derekwarner_decoy »
Offline Doonie
Re: PS Bellarine
« Reply #20 on: January 20, 2014, 06:08:02 PM »
G'day Derek,
I just threw that in there for interest sake.   Mebbe a tiny bit every now and again but mostly about the Bellarine, now PMS Dispatch, which by the way I have done a bit on since me bits arrived from the US and Hong Kong.
Pic 1 where I'm at.
Pic 2 forward compartment - battery esc.
Offline Doonie
Re: PS Bellarine
« Reply #21 on: January 20, 2014, 06:09:30 PM »
and
Offline Doonie
Re: PS Bellarine
« Reply #22 on: January 20, 2014, 06:10:36 PM »
Pic 3 motors hooked up with dpdt switch to swap poles on left motor which enables spin on the spot left or right to get out of trouble.
Offline Doonie
Re: PS Bellarine
« Reply #23 on: January 20, 2014, 06:11:42 PM »
Pic 4 stern compartment, steering servo and receiver.
Offline Doonie
Re: PS Bellarine
« Reply #24 on: January 20, 2014, 06:15:13 PM »
Pic 5 smoke maker roughly in position.
Still need to decide how to make the paddlewheels.   Any info re that would be gratefully received.
Re the Bootlegger Rudder.   I dunno.   In fact I dunno if the thing will thrash itself to death or not when all that power gets unleashed from that huge motor.
Model boat building is a bit of an out there I dunno what will happen, argh stuff it lets have a go experience I reckon.
Cheers, thanks for the interest.
Re: PS Bellarine
« Reply #25 on: January 23, 2014, 02:26:17 AM »
The way I make paddle wheels can be seen on this site. Construction,  Duke of Devonshire, page 4&5.
Offline kurlander
Re: PS Bellarine
« Reply #26 on: January 23, 2014, 06:52:47 AM »
I see that you are using the same model of smoke machine as I am.
After I received mine, I modified it to hold more oil and it now runs well over an hour. I found a plastic box in my attic that was the same height as the steam machine.I carefully drilled a small hole into the side of the machine and the box as close to the bottom as possible and joined them together with a plastic tube. The level of the liquid will be the same height in both containers.
Enclosed are two photographs.
Offline Doonie
Re: PS Bellarine
« Reply #27 on: January 23, 2014, 08:17:38 AM »
Excellent work, thanks for that.
Doonie
Offline Doonie
Re: PS Bellarine
« Reply #28 on: January 23, 2014, 08:18:54 AM »
Good tip thanks for that, and I have been enjoying watching your build.
Thanks,
Doonie.
Offline kurlander
Re: PS Bellarine
« Reply #29 on: January 23, 2014, 03:20:58 PM »
Thanks for the replies.
I have built three boats,wrecked two built for speed and two cars overbuilt for speed.
This is my first attempt to build something just from blueprints. I have realized that if I give enough time to analyze a problem in building I will solve the problem.
There are several issues I have to think about such as how to put steam at the back of the boat to make it look like the caliopy is playing.
