Author Topic: Lady of the lake.  (Read 23304 times)
Re: Lady of the lake.
« Reply #15 on: August 23, 2014, 01:41:33 PM »
A bit of minor storm damage there Damien  :crash.......we will be watching as you make the repairs
In real life...all ships need a bit of time in dock for a refit  :ranting
Just press on......the vessel & you will be fine   :beer ..... Derek
Offline the bombus
« Reply #16 on: August 23, 2014, 04:45:38 PM »
iceberg !!! they always said ! now i know what hit the Titanic  :)
One thing is clear , the Damiendock will fix it ,i'm sure of it .
keep the spirit pal.
greetings from The Bombus
and maybe it will work
« Reply #17 on: August 24, 2014, 05:02:24 PM »
Thanks everyone have a bruised Bum my pride hurts more though. I've finished my lathe motor conversion rest of day for clean up will start the repairs monday or tuesday.
Stay tuned for more   ;)
Offline Gerhardvienna
« Reply #18 on: August 24, 2014, 05:54:19 PM »
I WILL!
And i think, it will all be repaired well, as I believe you can do it!
Greetings
Gerhard
« Reply #19 on: August 25, 2014, 09:17:58 PM »
The stanchions and railings are now straight all other damage treated to liberal amounts of super glue.
Not sure how to tackle the broke 1/4sq on the hull bottom rise at the bow it's been pushed in about 10mm I can't get at it from inside the hull I'm so thinking of a small screw eye into the 1/4 sq and trying to pull it out.
« Reply #20 on: August 27, 2014, 01:26:03 AM »
Hi Damien
You could try to make yourself a tool like shown in the link http://www.dellenwerkzeug24.de/zebay/hebel/spitzen.jpg this is made for smart repairs on cars, why should this not work on model ships!
Regards Gerhard
« Reply #21 on: August 27, 2014, 10:09:24 AM »
I tried tried the screw eye into the cracked 1/4sq with cord threw the eye I held the boat while my wife pulled on the cord, this is as far as the dent would pull out.
So I changed tack and removed the the broken strip wood and rough sanded the area ready to receive bog filler.
« Last Edit: October 20, 2017, 11:31:46 AM by DamienG »
« Reply #22 on: August 27, 2014, 06:43:49 PM »
Filler applied and sanded ready for primer I think I'll have to mix new deep red for below the waterline as it was hand mixed I still have the grey above waterline paint and the railings are an off the shelf colour.
I used artists sketch pad paper wrapped around a berocca can as I did the original and cut balsa inserts to strengthen the tube.
It won't take as long as I first thought to make her ship shape.    :) :)
« Last Edit: October 20, 2017, 11:32:22 AM by DamienG »
« Reply #23 on: August 27, 2014, 07:36:05 PM »
Hi Damien
Looks good, well repair! A little bit of paint, and there is a perfect hull again.
Greetings Gerhard
« Reply #24 on: August 28, 2014, 07:55:26 PM »
Thanks Gerhard.
Rings added to the funnel 4mm strips of sketch paper attached with doll house wallpaper glue looked like really thinned PVA.
« Last Edit: October 20, 2017, 11:32:57 AM by DamienG »
« Reply #25 on: September 02, 2014, 05:27:14 PM »
This repair was much easier than I imagined during the stress of the fall that caused the damage.
The hull has repaired with a few minor imperfections.
The twisted wire rails are the best I can get them the touch up paint was close but not quite the same colour but what touch ups on any machinery is perfect?
The new funnel held in place with lead buttons while the epoxy dries.
 All that remains is to refit the paddles and the radio gear.
« Last Edit: October 20, 2017, 11:33:45 AM by DamienG »
Harold H. Duncan
« Reply #26 on: September 02, 2014, 05:32:33 PM »
very nicely done that man. :)
« Reply #27 on: September 02, 2014, 06:20:39 PM »
Thanks It a great relief to have it looking good again.
Offline the bombus
« Reply #28 on: September 03, 2014, 07:16:01 AM »
those are pictures from before the accident Damien  ;D
like i said the Damiendock will fix it
nicely done job
gr from The Bombus
« Reply #29 on: September 03, 2014, 09:55:42 AM »
Thanks mate In feel a lot better now it's back together.
