Author Topic: HELP !  (Read 2259 times)
PETER-T
HELP !
« on: August 05, 2013, 07:38:47 AM »
Hi, I'm a newbie to building paddle steamers. I'm building a 1:24 tug scaled up from the old model maker Cheiftain plans.
Building the boat's no problem but I've to build the gearboxes, what speed should the paddles be turning at ?
Peter T
Re: HELP !
« Reply #1 on: August 05, 2013, 11:09:52 AM »
Hi PD's....& welcome Peter.......... you mention [steamers] & also [gearbox's] ....so I assume you intend an electric drive.....
 :whistle a simple answer to your question for a 1:24 Chieftain class paddler would be a paddle shaft rotation to approx. 180 RPM max
Having said that.......with a low current consumption 12 volt electric geared motor + a good quality electronic speed controller will provide you with realistic start off speed [10 RPM] & take you to say 150 RPM for top speed
The 180 RPM is only a get out of trouble scenario, however the accurate scaling of the paddle wheel components will also have a dramatic effect of the paddling force provided
Now if my assumption of electric is incorrect  :oops....and real steam is intended, then essentially the speed requirements remain the same ....however steam  :kiss1 is a far bigger gambit & ball park
Take the time to read our archives.......any questions....don't hesitate to ask....Derek  :beer
PETER-T
Re: HELP !
« Reply #2 on: August 05, 2013, 12:55:21 PM »
Hi Derek, many thanks for the quick reply.  I'm using electric and I've got two 100 RPM epicyclical gearbox motors so driving  via toothed belts at 1.5 / 1.6 to 1 ratio will do the job.
I'd like to go steam but the cost of two engines etc. is beyond me !  Peter
