Paddlewheels/Drive Systems
Another Lulonga
Topic: Another Lulonga (Read 9301 times)
Tomas Krejci
when the ship .. so only on the hill
Another Lulonga
February 17, 2013, 08:40:13 AM »
Part 1
Another Lulonga - paddle Wheel
When building a model paddle steamer Lulonga I had to solve the design of the wheel, which would be as simple as possible and still meet my requirements for my simple production conditions.
I came to an interesting Russian sites SEATech , which designed the paddle steamers, but the wheel are specially shaped => this is also one in my post here on Paddleducks
http://wheelships.ru/
http://wheelships.ru/index.php/joomla-license
This idea appealed to me, so I decided to use it in the construction of the model paddle wheels for Lulonga model.
Here I would like to first point out that the wheel on some sternwheelers used earlier or less similar regulate water flow driven by skew blades so that the leaves were divided at halves in the middle of the big and broad wheel , flat and inclined against each other in the middle of a similar way.
This design was used among others in sternwheeler tug Verity. * (Article Geo.M.Verity)
See also the contribution from> towboat joe <> herringbone Wheel <
Aug 7/2007 to>
www.paddleducks.co.uk
similar shape of wheels we found, however, for other ships.
reason as stated above, that should reduce the noise level
But the most sophisticated use of such structural element brings up Russian patent from SEATECH , mentioned above.
Paddle wheels for Lulonga- description, history of development and construction
For my first model steam sidewheeler Ned Kelly * ( in the download Paddleducks section), I chose simple design wheel to test the two-cylinder steam engine Wilesco.
I had some cheap pieces of discarded sheets of fibreglass laminated by copper sheets(The board with copper on it is called "copper-clad laminate" too , primarily used for printed circuit board, or PCB technology, in this article “ CCL” ) . This material I used for model wheel blades .
The paddle wheel skeleton was formed by full plywood disc Ø 140 mm (plywood thickness 4mm), into which was inserted 8 blades , glued by epoxy( "CCL" 50x40 mm)
The paddle wheel skeleton was formed by full plywood disc Ø 140 mm (plywood thickness 4mm), into which was inserted 8 blades , glued by epoxy( "CCL" 50x40 mm).I glued everything on the template -wood block that allowed me to check the squareness of blades Next step was sticking wooden flange on the center of the disk, serving as a tenon for attachment to the wheel axis. the whole construction was then painted with thin epoxy and polyurethane varnish.
> 3 > Ned kelly wheel <
practical implementation
> Appendix figure > 4 > Ned Kelly paddle <
> 5 > Ned Kelly from behind <
As you can see from the photos, the wheel was mounted on the axis of a broader part of shoulder blades toward the fuselage.
Steam....GO!
Tomas Krejci
Another Lulonga 12
February 18, 2013, 08:52:46 AM »
…… Part 2
When driving this arrangement surprised me their efficiency. It probably contributed to the fact that the model side, along which the blades were moving was practically straight and parallel to the longitudinal plane of the disc wheel, and formed a kind of plywood tray(between disc and model side) in which the blades were moving. I think it would enhance the effectiveness of paddle propulsion..Steam engine rev were reduced overall in the ratio of 6:1 (3:1 on the engine, then 3:1 reduction from chain drive to paddle wheel shaft; total resultant speed of model was sufficient even at minimal engine revolutions (50-60 rev / min on a paddle wheels)but at maximum speed (120 rev / min and above) the speed of model was unnaturaly too fast when compared with an average speed of original Australian steamers.
> Appendix foto 6> Ned Kelly > Engine room <
this design of paddlewheel I could not very well use for Lulonga, because I did not have a good waterproof plywood.In an effort to keep the design as simple as possible, I was forced to think of somewhat better and more durable construction.
Steam....GO!
Tomas Krejci
Re: Another Lulonga 13
February 18, 2013, 10:13:33 AM »
……………….. part 3
I needed a simple design producible at home without greater mechanization (milling cutter, lathe), which was also my case.
The main requirement was that I need two independently driven paddle wheels. Their design must allow for mounting and dismounting accessible on the driven shaft (steel rod Ø 4 mm), and especially their resultant structure should be strong enough.
The material, for which I again decided , were the Fiberglass copper coated thinner boards that I have used identically for model Ned Kelly .. This would partly be used to construct design both soldered and glued. I finally chose bonding by epoxy glue. In addition, the material is definitely stronger than the sheets of hardened polystyrene recommended in Lulonga drawings . Of course,here could be used directly thin fiberglass sheets, and reinforced structure by small rivets. The use of Aircraf or waterproof plywood I did leave due the price of such stuff.
Here at Paddleducks, you will find many inspirations both in material and in its use .. just choose what suits you best.
As a basis I used the wheel drawing from original drawing in the scale 1:32( in plan from David Metcalf,> Quarter-wheeler River Paddle Tug Lulonga <Magazine> Model Boats <), which I repainted separately on paper
> Annex image> 7>
the outside diameter of the paddlewheels is 140 mm
Last Edit: February 22, 2013, 05:19:58 AM by Tomas Krejci
Steam....GO!
Tomas Krejci
Another Lulonga 14
February 21, 2013, 08:52:47 AM »
Part 4
Mesasured pieces of wheel I cut with shears and filed down with flat file. I cut the notches into spokes with a hacksaw with intent to insert at the end blades into notches . I made spokes a bit wider, due to the strength, nevertheless the greater width of spokes does not hamper movement of the wheel in the water . The wheel spokes I cut toward the center of the wheel , as in figure 7B ( like the wheel structure sternwheeler Okahumkee -here at Paddleducks.
Side view of wheel I drew on paper which I put into the transparent PE envelope..This envelope I put to the surface of the hardboard . The PE envelope allow individual parts directly glued after attaching them together at the envelope surface.Individual parts I pinned up to the appropriate place according to the drawing. (through drawing to hardboard pad) and glued with epoxy glue.
Each side of the wheel had 8 spokes, glued again on the middle part of CCL in which are the pre-drilled holes Ø 6mm for false shaft . I had not circle cutter , so I cut the middle parts as squares.
After hardening of epoxy I have glued the same part ( for strengthening of joints ) to opposite side, rotated by an angle of 45 ° .To maintain perpendicularity of siderails to the shaft , I put small wooden flange at the center of the wheel , (to make flange joint ) and let harden it in the simple wooden jig. After preparing the template, I then glued 4 equal siderails this way.
As a next and final step I placed subsequently these prepared parts symmetrically ,(flanges inside),at an auxiliary (false) shaft , made of Cu pipe Ø 6 / 4, 2mm and set 40 mm pitch between siderails.
Now, after a moment's hesitation, I made an important decision - when I glued prepared "star" sides to auxiliary shaft ,I turned these against each other slightly about the width of spoke ( approximately by 10 ° here), likewise to the aforementioned Russian patent.
When building wheels with angled blades, so dashed line in Figure 7 indicate position for the second wheel side !!
Here need to be careful .. if you also wanted to make such adjusted wheel .. => Wheel are symmetrical and mirrored ! So then here are the left wheel and the right wheel, and these can not be (or..should not in any case) interchanged.
> foto 8 >
> foto 9 >
After the curing of the adhesive on the axes , followed by sticking blades, again on a wooden template jig, for adjusting the equal lateral height of blades.
> foto 10>
>foto 11>
Last Edit: February 22, 2013, 06:00:17 AM by Tomas Krejci
Steam....GO!
Tomas Krejci
Re: Another Lulonga
March 08, 2013, 07:18:14 AM »
part 15
The next step was to attach the side brass flanges (cuffs) to the copper tube at the inside of the wheels.. After inserting the flanges I marked the place where the copper shaft is drilled and with screw (grub screw ) M4 tightened on its own drive shaft, (consisting of a steel rod Ø 4mm.)
The drive shaft may be common to both wheels, but now I have it split, each wheel has its own drive( geared electric motor DC 12V with ESC )
Drive shafts are each placed in two brass bearings, one on the inside of the paddle wheel box , the outer at longitudinal paddlebox reinforcement.
On the inside of the shaft in the hull, there are deployed flanges of toothed belt gears .
> Image 12 >
> Image 13 >
Paddle wheels on the outside are covered with covers from GPPS with mounting hole, allowing assembly and disassembly of paddle wheels .against orginal version of covers I made some improvements .
> Image 14 >
> Image 15 > ..
Steam....GO!
Tomas Krejci
Re: Another Lulonga
March 08, 2013, 07:38:06 AM »
At the end of this chapter I put photo of my live steam model Ned Kelly ..
I was convinced that here at Paddleducks must be somewhere photos of my model Ned Kelly too ,
nevertheless somewhere over the rainbow ....
Steam....GO!
Harold H. Duncan
Re: Another Lulonga
March 08, 2013, 03:36:30 PM »
Very nice Tomas,
both models.
kiwi
Another Lulonga
