Author Topic: Almost a Jose Olson  (Read 9358 times)
Offline Spankbucket
  • Emigre from South London
Re: Almost a Jose Olson
« Reply #15 on: August 28, 2012, 05:47:30 PM »
Very Nice indeed!!!
« Reply #16 on: August 30, 2012, 10:43:38 AM »
I personally would not use anything else, it makes a nice strong , light weight set of paddles. But others will probably disagree.
Hi Chris,
In reply to the above quote ...
Probably ... lol
I have to say that don't I?
Having said that i will have styrene & ABS alterantives with me at the Paddler day this year (2012)... after all , the customer is allways right .... to quote a friend ... '' until proven otherwise''...
But seriously, i like the build !
Me and Mr Mark's Model Boat Bits might benefit from a chat.
Offline chipmonk
« Reply #17 on: August 31, 2012, 06:11:54 AM »
Hi all
I am glad you like my efforts, and I would be happy to chat about using styrene sheet for paddles etc.
Cheers Chris
« Reply #18 on: September 03, 2012, 08:32:39 AM »
That was fun to draw out on my CAD program, as the laser cutter cuts with a 0.5mm line and the ones on the drawing were about 1,2mm  :evil.
Using this technique I have made workable wheels up to 200mm (8") diameter and have not has one fail yet ( I have lost count how many I have made it is well into double figures). All welded with "Slater's Mekpac" adhesive.
Cheers Chris M
Hi Chris,
I did a quick survey on materials just before starting production & also quite happy with the use of Styrene on my Laser But by all means if you want to start a discussion I'm happy to put my two penths worth in ...
Just going back to the first quote .. If it's your own Laser & your getting a 0.5mm Kerf on the cut in 1mm Styrene ... I'd be looking at the focus (typical Kerf is usually about 2 X Beam width so either it is a low power laser of Laser is out of focus /needs a wee clean ;)  maybe? (Excluding Pulse rate at the moment)
Regardless, your line weight at the drawing stage the laser (usually) follows the centre of the Line ? Unless your using some exotic software that I'm not aware of.
I know you did look into gettting a laser cutter and happy to help if i can.
