Author Topic: Hello from the owner of the Lorna doone 2  (Read 2660 times)
Lornadoone2
« on: February 12, 2012, 08:33:19 PM »
Hello just thought i should say hi.
i am new to the paddler community and am restoring a 40yr old r/c model of the Lorna Doone2 she is just in need of the power plant (electric) to go in a graupner bb720 torque
Re: Hello from the owner of the Lorna doone 2
« Reply #1 on: February 12, 2012, 09:29:09 PM »
LD2...here is the same message I posted on Model Mayhem for you today....PeeWee & Talisman [Kim] also posted a response to you......... :whistle ......
mmmmmmmmmmmmmmm according to GOOGLE, the 720BB = 4100 RPM no load......is a bb720 and a 720BB the same item?
Speed 720 BB TORQUE SMC-M-6372
Nominal Voltage 12.0v - Voltage Range 6.0 - 13v - No load RPM 4,100 - No Load Current 0.75 A - Current @ Max Efficiency 3.0 A - Stalled Current 13A - Max Efficiency 75% - Case length mm 72.0 - Case dia. mm 44.5 - Free shaft length mm 6.5 - Shaft Dia. mm 5.00 - Weight (g)380
Optimal paddle shaft speed for a model paddler of 5' is in the order of 150 RPM....with the ability to reduce that further with a speed controller....so if a bb720= a 720BB then you would need a reduction of say 25:1
Log in & have a look @ our paddleducks.uk WEB site .........you will find many references to this & discussions on common/single shaft drive as very few paddlers used independent drive for each wheel.... Derek  :coffee
« Reply #2 on: February 12, 2012, 10:29:20 PM »
Welcome to Paddleducks, it's always good to see someone restoring an older model to its former glory, and putting it back into use!
« Last Edit: February 12, 2012, 11:48:25 PM by Eddy Matthews »
« Reply #3 on: February 13, 2012, 01:17:17 AM »
welcome to Paddleducks, very good looking ship you have, would that be the Lorna Doon which was previously Queen of Kent and originally HMS Atherstone? - often thought about building one of those as a minesweeper....
Lornadoone2
« Reply #4 on: February 13, 2012, 02:01:06 AM »
That is the one i think its one of the nicer vessels to ply the south coast she really just needs the motor and drive system fitting belt drive maybe?
