Author Topic: Larry's Lulonga build  (Read 32330 times)
Offline jelley_baby
Re: Larry's Lulonga build
« Reply #15 on: November 11, 2011, 07:21:08 AM »
Hi Larry,
She was running on Como Drill 919D motors with a 50:1 reduction and from them a 2:1 chain drive using Meccano sprockets and chain, and running on 12 Volts the paddle rotation was about 100rpm but the weight of two motors (she steered with independent motor control) no rudder, and will turn in her own length, which is a spectacle. I have fitted 2 Como drill 280's which do not have the same power but seem OK I will know more when she sails after refit.
Mine is built on an injection moulded hull and in some ways that is better as long as you make very good seal between it and the deck.
Regards Graham
LARRY W
« Reply #16 on: November 12, 2011, 08:00:51 AM »
  THANK YOU FOR INFO......LARRY....
« Reply #17 on: November 12, 2011, 11:28:39 AM »
Hi PD's :whistle........you have made a grand start here Larry...in such a short time ...carry on....& keep posting the  :kewlpics ......
You can now see there is an alternate to life [here] other than on MAYHEM .......Derek   :beer
LARRY W
« Reply #18 on: November 18, 2011, 06:19:33 AM »
HI ALL,
            moving on a bit more,    hull and paddles ,    can body help with drive chain ,
 ALSO LOOKING FOR MAGAZINES WITH WRITE BUILD WRITE UPS ?     still looking ..... LARRY...
« Last Edit: November 18, 2011, 06:23:46 AM by LARRY W »
Offline Spankbucket
  • Emigre from South London
« Reply #19 on: November 18, 2011, 06:27:02 AM »
Hi Larry
I have just bought some chain and sprockets from this eBay supplier who I have used before:
http://www.ebay.co.uk/itm/160676278763?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I have been fitting them in today.
His prices seem very reasonable and the delivery/service is instantaneous. I thoroughly recommend him.
You're making some very impressive progress and I look forward to more of the same!!!
Cheers.......Bernie
LARRY W
« Reply #20 on: November 18, 2011, 07:12:01 AM »
 THANK YOU ,
                     had a look at web page ,    of chain and gears , will come back to it when i get motors,  LARRY..
LARRY W
« Reply #21 on: November 19, 2011, 07:22:06 AM »
HI ALL,
          worked on deck house and deck planking using Ikea blind slats.
     a   Favorite build material of mine  note sheet planking pieces butted and glued together and sanded .  .......LARRY...
Offline Spankbucket
« Reply #22 on: November 19, 2011, 08:25:27 AM »
Nice work Larry and quick!!!
Cheers.........Bernie
LARRY W
« Reply #23 on: November 19, 2011, 08:34:21 AM »
HI  BERNIE,
                   thanks its better than the telly :beer  you seem to be the only one  interested ,.
               am i using the wrong soap ;)  Larry....
« Reply #24 on: November 19, 2011, 09:16:18 AM »
Larry,
I'm with you on the Telly front!
Please don't take lack of reply as a sign of lack of interest ... Personally i'm amazed at the speed your going. I'm sure if there were better ways or you were going the wrong way about things you might have heard.
So, well done & keep going we have our eyes on you!
Offline jelley_baby
« Reply #25 on: November 19, 2011, 10:53:04 AM »
Hi Larry,
Have notification of your posts sent to my email, so am watching with interest. At the moment am building up a kit that I have had for nearly five years and work on when I feel in the mood, its a billing Banckert, not a paddler, at the moment build the superstructure on trying to ballest it in the bath, with lead shot.
You are progressing well with your build keep going, and perhaps I will get restared on my rebuild, the last thing I did was to replace the railings all round the decks, very time consuming.
regards Graham
« Reply #26 on: November 20, 2011, 07:55:09 AM »
HI  BERNIE,
Hi Larry,
Your doing great and I am following, just don't want to clutter up the thread.
PS I just wish there was a "like" or "Interesting" button on posts so we could let the poster know we are out here.
Offline jelley_baby
« Reply #27 on: November 20, 2011, 09:19:13 PM »
Hi Larry,
Had a thought last night, while setting up my Banckert, most of the ballast you will need in the Lulonga will be made up by your battery, motors and radio gear, at least it is in mine, but be careful not to float her too near to the lower loading deck as water can very easily run over it when other boats are passing, that was my problem. Under the lower side decks I have filled the cavity with Polyurethane but you could use polystyrene blocks as a safety feature. As I said earlier I steer with in-dependant motors and no rudder, worth working on while you are building.
Will continue to watch your build. Graham
« Reply #28 on: November 21, 2011, 12:26:52 AM »
HI  BERNIE,
I'm following this build too (as I do all of them)  seems to be coming along well, it'l be interesting to see how the finished boat sails  ;D
LARRY W
« Reply #29 on: November 21, 2011, 08:41:41 PM »
HI ALL ,
          Thank you for interest  ,   you are all a big help  :c017 .
        more done on deck houses ,  GRAHAM ,   will be going paddle steering so will be seeking help,
 also motor drive , paddle wheelers are a black art to me ,  :c002 thank you.
     MORE PICTURES SOON .... Larry.....
