Author Topic: Inspired by PS "Will O'the Wisp"  (Read 35085 times)
Offline Taifoon78
Re: Inspired by PS "Will O'the Wisp"
« Reply #45 on: December 04, 2013, 09:22:43 PM »
I presume that the plans and keel/hull sections are for a new model?
Cheers...Bernie
Yes. You are right :)  She will be a new "ocean going" paddle steamer.
Offline Spankbucket
  • Emigre from South London
« Reply #46 on: December 05, 2013, 12:21:58 AM »
OK......I look forward to your further progress with that.
Offline Taifoon78
« Reply #47 on: December 08, 2013, 10:19:59 PM »
Offline Taifoon78
« Reply #48 on: December 19, 2013, 08:35:22 PM »
 ;D
Offline Spankbucket
« Reply #49 on: December 20, 2013, 07:48:50 PM »
She's looking great!!!!
It looks like you are using hardwood so far?...I'd be interested in what type you are using.
Happy Xmas and a prosperous New Year.
Cheers...Bernie
Offline Taifoon78
« Reply #50 on: December 27, 2013, 11:37:42 PM »
Thank you  :)
Yes. You are right. In this hull I used pine planks 2x2mm and 2x10mm for stringers, 3x4mm for keel. For frames, stem and stern-post I use a 1mm plywood. It made possible to use a scissor for cuting frames. Also for stern and stem I used a balsa wood plank.
Happy Xmass and a New Year.
Offline Spankbucket
« Reply #51 on: December 28, 2013, 08:01:18 PM »
Great Idea!!!
Where did you source such small thickness  pine wood? My guess is you cut/planed it for yourself?
Good Luck for 2014
Cheers...Bernie
Offline Taifoon78
« Reply #52 on: January 02, 2014, 04:34:08 AM »
Happy New Year!
I had a luck to find a bit of this wood in one small modeling shop in my town. It is an components for building a planes models. In another case, I will forced to cut a planks from a wooden rulers or buy it is in the internet or order it is in a carpentry workshop. In this case it will be a few expensive and аlso it will take a little more time.
Offline Taifoon78
« Reply #53 on: May 01, 2015, 04:15:48 AM »
Work in progress ))
Offline Spankbucket
« Reply #54 on: May 01, 2015, 05:36:42 PM »
Looking really good and...you have a pair!!
Offline Taifoon78
« Reply #55 on: June 19, 2015, 06:05:09 PM »
Thank you. I use the same technology.
And here you can see paddle boxes frames
Offline Spankbucket
« Reply #56 on: June 20, 2015, 07:18:08 PM »
So there are 2   ... great ... look forward to future build pics.
Offline Taifoon78
« Reply #57 on: August 07, 2015, 05:46:20 AM »
I had find my first paddle steamer. And now you can see three generation of my paddle steamers on one photo. )))
Offline Taifoon78
« Reply #58 on: August 07, 2015, 05:51:04 AM »
First time afloat. The hull was varnished.
And the hull before varnish.
Offline Taifoon78
« Reply #59 on: August 07, 2015, 05:59:58 AM »
And here you can see how the project was redesigned.
