Author Topic: Peewees' MOL  (Read 23718 times)
Re: Peewees' MOL
« Reply #30 on: August 01, 2010, 03:51:57 AM »
Ian,
Re the solder solder / thread lock
If you use thread lock on the hubs and  i have used soft solder on the other nuts and bolts.
i have emailed over a copy of the instructions in case you are missing these.
Cheers,
Offline PeeWee
Re: Peewees' MOL
« Reply #31 on: August 22, 2010, 01:29:37 AM »
Hi All,
Well after a 10 day walking holiday in the Scottish Highlands and then some forced DIY (kitchen revamp) i have been able to get some time in the workshop.
Following some thoughts around securing the nuts and bolts i decided to silver solder the Brass/Brass and loctite onto the Hubs.  Since i havenot Silver Soldered for awhile it took awhile especially with all the acid dipping and prep.
here are the results.
a close up of one of the paddles
the control rods only have the nut/bolt silver soldered and the control rods are free to move
All i have to do now is to fit them all into the rims
hopefully tomorrow i will have a set of paddlewheels.  does anyone know what colour they were painted?
Offline djcf
Re: Peewees' MOL
« Reply #32 on: August 22, 2010, 05:02:56 AM »
Hi Ian,
Something like a Halfords red primer should be pretty close to the mark.
Offline PeeWee
Re: Peewees' MOL
« Reply #33 on: August 23, 2010, 02:41:19 AM »
Hi All,
Thanks Clark for the sugestion.
Today i did the final asembly of the wheels and painted them in Red primer as i had some in the shop.
i feel a small milestone has been reached.  all be it a very small stone.
Re: Peewees' MOL
« Reply #34 on: August 23, 2010, 02:46:59 AM »
Looking good Ian, though I have to admit that I'm not sure about the size of rod you've chosen for the axle :hehe
Re: Peewees' MOL
« Reply #35 on: August 23, 2010, 06:02:12 AM »
Hi Ian,
I'm very impressed with the solder work. Looking forward to seeing the rest take shape.
Re: Peewees' MOL
« Reply #36 on: August 23, 2010, 06:22:53 AM »
& Ian says.... "Well after a 10 day walking holiday in the Scottish Highlands" ..... :whistle ...I reckon he would have been better going to his local Bottlo ....buying a cask of his favourite Scottish mist & spent the next nine days in the workshop  :hammer
Anyway .....great job on the wheels.... :s_cool .,...Derek
Offline PeeWee
Re: Peewees' MOL
« Reply #37 on: August 24, 2010, 03:19:39 AM »
Eddy, you know how it is with all this cost cutting these days.  lets hope the motors don't put too much strain on it.
Derek,  don't worry, the wife insisted on a couple to distillery tours and i freely opened the wallet.
Well spent some time in the shop again today.  i have roughly cut out the deck that now needs sanding so that it will lower into the hull for the planking.  i also made the 2 main structures.  the roofs were re-cut with thinner ply then that supplied as they too will be planked.4
since the plastic is very thin a few supports were added.  see the deliberate mistake in the following picture
 :shoot
Re: Peewees' MOL
« Reply #38 on: August 24, 2010, 04:59:36 AM »
some of the windows look a bit low..... :-\
Offline PeeWee
Re: Peewees' MOL
« Reply #39 on: August 24, 2010, 05:48:46 AM »
yep, will have to cut the 3 front sides off and re do them.  hopefully i have some thin styrene
Re: Peewees' MOL
« Reply #40 on: August 24, 2010, 07:53:10 AM »
Ian,
Good to see others can make similar mistakes.
Some spares will be in the post in the morning for you.
Offline PeeWee
Re: Peewees' MOL
« Reply #41 on: August 24, 2010, 04:59:33 PM »
Cheers Kim, but please don't put your self out as you have a very busy week.  I can make up a replacement.
I forgot to ask in my last post,  does anyone have any info in the following area.  its the front rear port side.  the plans seem to show a couple of doors.  one under the ladder and one in on the rear.  i would like confirmation before compleating this area.
Re: Peewees' MOL
« Reply #42 on: August 24, 2010, 05:36:07 PM »
Hi Ian,
Your right there is a door under the steps going to the bridge.
there is a door just to the starboard side of the steps at the rear of the house.
There is a window just to starboard of the centre line of the house (rear)
I haven't cut these as the position sizing of the rear panel will depend on the width of steps bought or made.
Does that help? I have had a look at my pics and can't find one of that area.
Offline PeeWee
Re: Peewees' MOL
« Reply #43 on: August 24, 2010, 06:19:05 PM »
Cheers Kim,  just needed a sanity check  :D
Re: Peewees' MOL
« Reply #44 on: August 25, 2010, 05:42:55 AM »
Hi Peewee.
Could you not cut the front three sides as a block and invert them  ?  I've found that plastic will accept this method.
Ken
