Author Topic: Wee Lorne Build  (Read 23678 times)
Wee Lorne Build
« on: March 10, 2010, 08:54:10 AM »
Hi All,
As most of you know there are soon to be a few 'Wee Lornes' about to be built.
Personally I have a rather tight deadline, nothing like a little pressure to focus the mind  :a102  (9th of April all paint & glue needs to be dry)
So today I made a very small start, sorry no interesting photos just yet, best I can do until all the bits and bobs arrive.
These aren't recommendations just the way I have chosen to do things.
Today's Shopping list
Reade models - cowl vents.
Vapextech  - 4600mAh SubC tagged 1.2v cells
1M of 30mm heat shrink 2:1
9M of 1mm self adhesive Gold nail tape
1 roll of 3mm white coach line
3 x Mini tamiya conections (M&F)
1 x Electronize FR15
1 x 200rpm 12v geared motor (I'm not the biggest fan of geared motors but I'm on a deadline)
2 x Timing pulleys
1 x Timing belt
1 x Halfords Red Oxide Primer
1 X Japlac Artic White enamel
1 X Japlac Gloss Black enamel
1 X Blade fuse holder
James Lane - 1:48 3ball & capping rail spike Stanchions ( i have ordered way more than i need so apologise if your looking for an exact figure)
1 x Calder Craft 1:48 Anchor Winch
2 x Quay Craft 1:48 Scale 18ft Clinker Lifeboat
1 x 2 AA battery holder with leads (for lights) (2.4 volt with nicads)
?? x 1mm 3v Grain of rice bulbs
1 x Tesco portable mp3 speaker (lightweight and a bargain at about £4.00)
1 x Cheap & lightweight mp3 player
50 x Assorted 1:48 People
So tommorrow's jobs -
Make 2 x 6volt 'Sausage' Battery packs (so i can lay batteries along the keel line) 6v ahead of paddle wheels 6 volts behind paddle wheels.
Give the little people a flesh tone
Paint Vents (silver and blue)
Persuade the wife to free up some more surface area in the living room for the new addition :)
I very much Hope those of you that have 'Wee Lornes' ordered will Participate in this build.
Re: Wee Lorne Build
« Reply #1 on: March 10, 2010, 09:04:58 AM »
Funny you should mention it Kim, I was just talking to Stuart about his Wee Lorne build, and wouldn't you know it he's considering making his steam powered!
It will be interesting to see how everyone that has purchased a kit tackles the various bit's and pieces - Remember, there's no right way, just what works for you!
Really looking forward to everyone participating in the build, it should make fascinating reading!
Re: Wee Lorne Build
« Reply #2 on: March 10, 2010, 09:23:11 AM »
 :respect  Absolutely Brilliant!!
Absolutely right (Although personally I'd be following Stuarts lead)
Yep, I'm totally humbled by the interest in this wee project and if it helps to get paddlers noticed I'd be over the moon!!
Thanks,
Re: Wee Lorne Build
« Reply #3 on: March 10, 2010, 06:57:54 PM »
I'm looking forward to it as well. Especially as this will be the first square windowed paddler I've built - quite a challange. I have a Proteus steam plant that has been languishing in a box - new for about 6 years. Lorne seems the ideal candidate!
stuart
Offline PeeWee
Re: Wee Lorne Build
« Reply #4 on: March 10, 2010, 07:24:50 PM »
Hi All,
i have also been looking at sources for the additional items required, it will be very intresting to see how we differ in our approaches.  i have to admit though that i am most likely to be using the ideas more than helping others,  :shhh having said that i will try to come up with some ideas. :thinking
Like Stuart i have avoided square windows so that will be intresting to see.
The slipway is almost cleared and ready.
« Last Edit: March 10, 2010, 07:35:10 PM by PeeWee »
Offline djcf
Re: Wee Lorne Build
« Reply #5 on: March 11, 2010, 08:36:12 AM »
Hi all,
Looking forward to seeing progress on all the " wee Lornes".  The real ship used to serve the piers in the Holy loch area, near to where I live, for most of her life.
Thats one tight deadline, Kim...go for it  ;D    she will make a nice fleetmate for Jupiter. By the way do you have an address for James Lane fittings? Couldn't find it online
Found this old postcard of her
Re: Wee Lorne Build
« Reply #6 on: March 11, 2010, 08:40:26 AM »
JAMES LANE (Display Models)
30 Broadway
Blyth
Northumberland
NE24 2PP
Offline djcf
Re: Wee Lorne Build
« Reply #7 on: March 11, 2010, 08:53:11 AM »
Cheers Eddy
Re: Wee Lorne Build
« Reply #8 on: March 11, 2010, 09:27:52 AM »
Cheers Clark, that's a great photo and answers a discrepancy on my drawings i will amend my own drawings to suit. (2 vents at stern not shown on all builders drawings)
Not much to report today, i did get my battery packs started. I have never built a battery pack before so have included pics of the first steps.
1. Solder + to - tabs. Tip leave all protective sleeves on tabs until needed to avoid shorting and spectacular sparks :)
2. I have taped Kebab skewers at three points - mainly to prevent any movement in the solder joints but also to stop batteries rolling around the hull.
More to report tommorrow i hope,
Re: Wee Lorne Build
« Reply #9 on: March 11, 2010, 11:55:34 PM »
When I used to run fast electric I never used the tabbed cells and just soldered cells end to end. A good buddy of mine designed a soldering tip for soldering guns that had a copper disk that fitted in between the cells, you put a ring of solder on each side slipped it between the cells, turned on the gun and when the solder melted pulled the tip out and jammed the cells together. I will have to look and see if I still have mine.
sandystrone
Re: Wee Lorne Build
« Reply #10 on: March 12, 2010, 05:56:08 AM »
There was a build article on MARCHIONESS OF LORNE in the November 1977 MODEL BOATS MAGAZINE.
I have built her at 5/16" to the foot, and she passed to our Eddy, and is still in the Darlington club
        Sandy
sandystrone
Re: Wee Lorne Build
« Reply #11 on: March 12, 2010, 07:57:10 AM »
Gourock
Re: Wee Lorne Build
« Reply #12 on: March 12, 2010, 08:05:38 AM »
Did the Wee Lorne ever use that blue hulled colour scheme that Waverley had once?
Offline djcf
Re: Wee Lorne Build
« Reply #13 on: March 12, 2010, 08:11:01 AM »
Hi Eddy,
In a word , no!
The monastral blue hull scheme was 1965 - 69, the "Lorne" only lasted till the mid 50s.
Waverley, Caledonia and Talisman were the only three Clyde paddlers to see that livery.
Re: Wee Lorne Build
« Reply #14 on: March 12, 2010, 08:18:58 AM »
Sandy, Many thanks for the Pic very useful.
Cheers
