Author Topic: Making windows  (Read 9291 times)
Re: Making windows
« Reply #15 on: December 05, 2009, 06:48:44 PM »
Hi All,
A question -
Does anybody have any tips on making brass look like wood. I have tried wood stain only problem is every time i apply a new coat it lifts the previous coat.
Many thanks,
Re: Making windows
« Reply #16 on: December 05, 2009, 11:18:00 PM »
Kim,
I can't really think of any method to simulate wood on a brass frame. But what about getting them laser cut from thin ply?
I would imagine they would be cheaper to produce, and purchasers could then stain/paint them to give any desired finish....
Re: Making windows
« Reply #17 on: December 06, 2009, 12:05:15 AM »
Hi PD's ......Talisman....brass being a 'noble' metal will tarnish.........with age & oxidation.....a solution of nitric acid 25% WW will promote darkening but not simulate wood  :whistle..... Derek
Re: Making windows
« Reply #18 on: December 06, 2009, 12:25:46 AM »
One method you can try is to glue the frame face down onto a good cartrige paper (a SPRAY contact adhesive used according to the instructions regarding tack time or very thin superglue is fine.) Trim the paper around the frame using a scalpal (you will be amazed at how easy it is to get a crisp, sharp edge just by running the blade around the frame (always use a NEW blade). Then use stain or watercolour paint to get the finish you want on the paper and finally varnish. This is a standard technique used in the architectural model making business.
Hope this helps
stuart
« Last Edit: December 06, 2009, 12:30:15 AM by Stuart Badger »
Re: Making windows
« Reply #19 on: December 06, 2009, 12:58:48 AM »
Stuarts posting (above) made me wonder, would it be possible to scale a photograph of the REAL window, and then use that as the paper covering for the brass frame?
I doubt you could get more realistic than a perfect scale replica of the real thing!
