Author Topic: Not a Glasgow Build  (Read 23800 times)
Offline djcf
Re: Not a Glasgow Build
« Reply #30 on: February 23, 2010, 07:41:55 AM »
Those radial fan vents look so much better...a very neat job indeed.
« Reply #31 on: February 24, 2010, 07:22:09 AM »
Not an easy job getting the fan vents cut equally - a look in my ever increasing mistakes box will confirm :)
You have made a very nice job of it. Keep it up.
Offline PeeWee
« Reply #32 on: February 24, 2010, 07:53:31 AM »
thank you for all the kind words and encouragement.  i know what you mean Chris about the lack of crisp edges.  should have another update in the next few days.
Offline PeeWee
« Reply #33 on: March 05, 2010, 06:23:54 PM »
not much of an update but i have now at least started painting and decided on the scheme.
image 1 general look, the white is VW Alpine
pic 2 shows that i have cut out and painted the ladder covers, these will be replaced with wood.
the final picture shows that i have not yet installed the rail top.  again this will be stained instead of painted.  also there is a painted rim to the deck.  the hull will be dark blue.
Offline PeeWee
« Reply #34 on: March 17, 2010, 07:01:12 AM »
Hi PD's
a small update, hull painted except for the boot top.  portholes have been upgraded from the kit.
« Reply #35 on: March 17, 2010, 07:19:45 AM »
That's a lovely clean build PeeWee - are you taking it to Paddleducks day?
Offline PeeWee
« Reply #36 on: March 17, 2010, 07:38:09 AM »
My plan is to definitely try to make it to the paddlerday.  here's hoping.
Online Eddy Matthews
« Reply #37 on: March 17, 2010, 07:42:01 AM »
It's only about a 2.5hr drive from Peterborough Ian, you could leave at 8am and be there in time for the bacon butties  :)
Offline PeeWee
« Reply #38 on: March 17, 2010, 07:01:13 PM »
Now how could i possibly refuse a bacon butty, it would simply be rude.  :whistle
this morning i dug out the paddle wheels that were put together a couple of months back.  i discovered a problem with them.  the small black push in plugs are coming loose and falling out.   :16
Have i missed a trick here? if so what as it would seem daft to have such a weakness in the design.
« Reply #39 on: March 17, 2010, 07:09:44 PM »
Ian,
The push in plugs are a design weakness in the Graupner paddlewheels. If they have been used more than once they are then a very loose fit and tend to fall out, that's also true if they haven't been inserted squarely.
Trying to get new plugs from Graupner is like asking for hens teeth! :(
So you have two choices, replace the plugs with suitable nuts and bolts, or get some new plugs - And as luck would have it I have some :D I don't have a full set, but maybe 30 or so.... If you want them send me a PM with your postal address and I'll pop em in an envelope and get them off to you...
Offline PeeWee
« Reply #40 on: March 17, 2010, 08:00:50 PM »
Hi Eddy,
thank you for your kind offer, long term i suppose the best would be old fashioned nuts and bolts.  you wouldn't by chance know what the best size would be?
« Reply #41 on: March 17, 2010, 10:02:31 PM »
Sorry Ian, I can't remember what size the bolts are.... My memory is terrible (and that's on a good day!)
Offline PeeWee
« Reply #42 on: March 19, 2010, 08:22:54 AM »
Hi PD's
Quick question,  is using a vinyl coach line cheating.  on previous models i have painted them but then tey are wider on warships
i was thinking of something like http://www.modellettering.com/catdetail.asp?categorycode=05
« Reply #43 on: March 19, 2010, 08:27:45 AM »
You'll probably find that coach line is used on 90% of models Ian, and it's far easier than painting a thin line with crisp edges!
« Reply #44 on: March 19, 2010, 09:10:08 AM »
Hi Ian,
These guys do 10m lengths and a lot cheaper if i remember right.
If it helps i have used trim / coach line on my KGV and its still clinging on strong 5+ years later and i didn't varnish over it.
http://www.trillogyltd.com/stickers-stripes/stripes/stripes-3mm-pin-white-10m-/prod_561.html
They used to / may still list on ebay.
Hope it is of help.
