Irish Royal Mail Steamer Connaught build
18
19
20
21
29
Topic: Irish Royal Mail Steamer Connaught build (Read 178606 times)
djcf
Reply #270 on:
February 26, 2010, 09:24:54 AM »
Hi Stuart,
I really like the shape of the houses on the sponsons...looking great by the way.
If it was my desicion about the rails i would go with the scale - black...goes with hull & funnels
Reply #271 on:
February 26, 2010, 07:14:57 PM »
reaches for tin of Humbol black and very small paintbrush!
PeeWee
Reply #272 on:
February 26, 2010, 08:33:47 PM »
Likewise as above go black, i am going to try the chemical blacking solution for the Brass on the Glasgow instead of paint just as an experiment.
Reply #273 on:
February 26, 2010, 10:27:18 PM »
Hi PD's.......& yes PeeWee...the black patina fluid for brass is
25% nitric acid + 2% each of nitrates of copper + selenium + silver ......
it does work..........Derek
Reply #274 on:
February 28, 2010, 02:37:50 AM »
Hi PDs
thanks for the opinions guys. I think I'm going to stick with painting the handrails rather than chemical blackening. The blackening fluid is difficult to control when components are in place - as are the handrails and stanchions and it's difficult to pre-colour them as the finish inevitably gets scraped/chipped off in the installation process.
I have fitted the rudder. I mounted a piece of brass tube and filled around it on the leading edge of the rudder. I then cut 3 slots the same size as the rudder hinges. The hinges are made of brass strip with a bearing of brass tube soldered to each one. A length of telescoping tube was then fed through to provide the pivot. and the whole assembly glued and pinned to the hull. I have NO IDEA how Connaught's rudder was hung - so I've done it in a way common to ships of her age.
I have also made a start on the staircases - they are virtually complete apart from the handrail and panel detail (plus of course staining and varnishing) If you are wondering why one appears to be leaning in the photos, it's because I have just placed them in position and the bases have not been sanded to match the deck camber yet.
You may also notice that the paddle box steps are in position - so soon I can get a coat of paint on and get it wet!
stuart
Reply #275 on:
February 28, 2010, 02:50:34 AM »
Magnificent Stuart!
The rudder extension is barely visible, and it's a very neat installation. Mind you, if it was my model and I was building it, I think I would have given up with those staircases! They really do look like a pain in the proverbial to get right!!
Reply #276 on:
March 01, 2010, 09:18:12 PM »
Hi PDs!
I blew the first rough coat of paint on the centre section last night. I shall be finishing the paint by hand with a brush. this coat gives me the base to work on. The idea was also to let me see what she looks like in full livery rather than part wood, part paint. I am still also working on the staircases (one finished one to go).
I took the model out of the workshop to blow the dust off and vacuum it before painting and used the opportunity to take some shots. So here they are!
More later.
stuart
Reply #277 on:
March 01, 2010, 10:37:37 PM »
Well PDs!
It was a lovely day here and my beautiful assistant fancied a swim....so........ it seemed like a good opportunity for Connaught's initiation to the wet stuff. I haven't weighed the ballast and batteries yet. But I think I have her trimmed about right - I might ballast her a little more depending on her stability. Static she seems to 'spring' back to the vertical when inclined - but of course all that could change under power. we'll see! She stayed bone dry inside and required surprisingly little ballast - I reckon about 10 kilos plus the batteries, once I've weighed everything I'll post the results.
Any way the first of the 'on the water shots'
all the best
stuart
Last Edit: March 02, 2010, 04:56:08 PM by Stuart Badger
marinemole
Reply #278 on:
March 01, 2010, 10:43:40 PM »
Fantastic. I suspect I have been like most people and failed to realise just how big this model is. She is superb!
PeeWee
Reply #279 on:
March 01, 2010, 11:36:57 PM »
that's one mighty fine elegant lady, superb.
Reply #280 on:
March 01, 2010, 11:37:51 PM »
Thanks! - I'll tell Ros! (my beautiful asistant!)
mjt60a
Reply #281 on:
March 01, 2010, 11:55:11 PM »
WOW! that's quite possibly the finest model paddler I've ever seen
Reply #282 on:
March 02, 2010, 12:31:13 AM »
Fantastic Stuart, looks like she's sitting very nicely in the water..... Oh and Connaught isn't bad either
Reply #283 on:
March 02, 2010, 12:33:54 AM »
thanks all! - I am SO pleased that her bottom's wet at last!
stuart
Talisman
Reply #284 on:
March 02, 2010, 02:30:51 AM »
Superb Stuart!
P.S. - Is that your stunt double sitting poolside? Have you had extra help? - I knew there was a reason for the speed of the build....
18
19
20
21
29
