Author Topic: member location  (Read 3047 times)
Offline scotfriend
member location
« on: October 26, 2008, 06:30:49 AM »
Hi Eddy,
just a question?
Would it be possible to add a UK map to the "member location" in a bigger scale to show more clearly where are the members in the UK, because there are only a lot of dots but not clear where they are.
Regards Hans
Re: member location
« Reply #1 on: October 26, 2008, 06:45:49 AM »
It's already there Hans - At the top of the screen you'll see a "down arrow" and the word "View".
Click on the "down arrow" to select the country you want, then click on "View". And there you go, a much larger map....
Red_Hamish
Re: member location
« Reply #2 on: October 26, 2008, 08:47:29 PM »
Hello all, I followed the instructions that you gave Eddy to see where or if I'd appear, Lo and behold it seems as though everyone has migrated to West of the Outer Hebrides.
Cheers
Jim
p.s. I'ms till not on the UK map  ;D
Re: member location
« Reply #3 on: October 27, 2008, 01:15:43 AM »
Hi Jim,
I found I had to do a Refresh to get everyone back home. I can locate you on the Europe Map as being in the UK, but the UK map does not go far enough north.
