Author Topic: gas container  (Read 15373 times)
Offline andy
gas container
« on: September 14, 2008, 09:51:00 PM »
Hi PD´s
my little steamer named SCHONDORF now I got the model nearly finished and now I have to start with the engine equipments. Boiler is under construction, RC servos ordered, but what I need is an gas container. I have no space to integrate such a big blue bottle from CAMPINGGAZ or similar. I need a little container with about 50mm diametre and about 100mm length. Does anyone here know where to buy such a part, or have I to built it myself? Has to be light and never corrosive.
What is the preferred material?
brass?
inox?
aluminium?
Andy
Re: gas container
« Reply #1 on: September 14, 2008, 10:47:18 PM »
Hi PD's.....yes Andy...a 50 diameter x 100 long Gas tank complete with valving is avaible from & depending on your location.......
1) forest-classics.co.uk/bix_spite.htm ...in UK
2) JMC in France
3) Anton....Fabrice in France
4) John Hemmens....UK
They all appear as brass construction & pressure tested to 25 Bar
My gas tank was purchased from ACS ........50 diameter x 120 long  ...with a dry or empty weight of 400 gm.......however I suspect it is very similar to those from forest-classics.co.uk/bix_spite.htm ..........Derek
« Last Edit: October 06, 2008, 11:16:14 AM by derekwarner_decoy »
Offline andy
Re: gas container
« Reply #2 on: September 15, 2008, 04:18:45 AM »
thanks! But I forgot to say, that the tqank has to be very light. Seems that I need an individual construction.
Re: gas container
« Reply #3 on: September 15, 2008, 08:21:47 AM »
Andy,
Refillable gas tanks have to be made to specified recommendations.
They have to be able to withstand such a high pressure in case the boat catches fire, so a lightweight 'safe' version is just not possible.
I have always had my doubts about putting commercial screw on gas containers in model boats. In the event of a fire, I am sure they would not be able to prevent rupture for very long, and I would be inclined to think that the devastation range would be something like 5 metres circumference around the boat, maybe a lot more. Devastation = engulfed in flames and flying debris.
Re: gas container
« Reply #4 on: September 15, 2008, 03:59:09 PM »
Hi PD's.........Andy - the only mention of a trial of aluminium gas tanks that I am aware of is by the French modeler Daniel Bourard....& he gave up as it was not a success..... :hammer :ranting.....
 http://translate.google.com/translate?hl=en&sl=fr&u=http://perso.wanadoo.fr/daniel.brouard/&prev=/search%3Fq%3Dhttp://perso.wanadoo.fr/daniel.brouard%26hl%3Den%26lr%3D%26sa%3DG
In Construction 1 or 2 from memory......No ...it appears that Daniel has taken many pages of the construction away....I will post a note to DB......
This is another good read relating to gas tanks...........Derek
http://www.bushwalking.org.au/FAQ/FAQ_Stoves.htm
« Last Edit: December 17, 2008, 09:25:49 PM by derekwarner_decoy »
Offline andy
Re: gas container
« Reply #5 on: September 15, 2008, 06:12:46 PM »
I think, I will use inox 0,5mm für the tank. Same as I took at the 2 tanks of my model of the PS DIESSEN, with filling valves from Ronson lighters. Tthis was calculated with the TÜV- norms in Germany, and if I compare the thickness of the gas bottles in which we can sell the gas, ist is much more.
Maybe I will buy an interruptor- valve for the tube to the burner.
If the model will burn- s..t, but what to do then? I have not the weight in it for an automatically workung extinguisher!
Andreas
Re: gas container
« Reply #6 on: September 15, 2008, 09:22:25 PM »
Andy,
It isn't a matter of saving the boat if it catches on fire, consider that as being a total loss.
It is all about protecting yourself and spectators from what will happen if the gas tank explodes, due to insufficient strength to contain the rapidly expanding, highly flammable gas.
A flashback arrester isn't the solution, a very strong gas tank is.
Re: gas container
« Reply #7 on: September 16, 2008, 06:11:42 AM »
Andy,
Sandy mentioned in one of his posts that the gas tanks are tested to 350 psi hydrostatically, so unless you have the skill and experience too build equipment that can be reliably tested to that buy a commercial unit.
Offline andy
Re: gas container
« Reply #8 on: October 06, 2008, 05:58:31 AM »
I will test it with about 5 atmosperes over natural earth pression, filled with water for a harmless explosion in this case. I have an compressor to do this. I donot want to loose the model, but I have to construct at the line between weight and security. I cannot make the parts as german Krupp- heavy metal.
Re: gas container
« Reply #9 on: October 06, 2008, 11:14:42 PM »
DO NOT USE AN AIR COMMPRESOR FOR TESTING TANKS. Tanks and boilers should only be tested hydrostatically with water and a hand pump(feed water pump), You need to test to 355Sig. 25bars that is 25 times over natural earth pressure. There is a very good article in September 2008 Model Boats by Peter Arnot that talks about tanks. You would be best to contact one of the before mentioned manufacturers and have them build a tank for you.
Re: gas container
« Reply #10 on: October 06, 2008, 11:45:48 PM »
Got in there before me Gerald.
Maybe this member doesn't really understand the consequences involved of storage of gas due to the language problem, maybe if someone could correct this by converting what has been said into German, and relaying the information that way. My German is limited to knife, fork and spoon.
Offline andy
Re: gas container
« Reply #11 on: October 07, 2008, 07:57:49 AM »
Maybe my English is not so good, but I can understand, what you mean here in the forum.
And I wrote, that I will fill the tank with water before testing it.
When I tested the boiler of my DIESSEN PS model I took the 8 atmospheres on it, when it was completely filled with water. And I was hidden behind 10 pieces of 25mm thik wooden plates. But nothing happened. Thickness of the boiler is 1,5mm inox. pressure in use about 2,5 atm.
What´s the problem?
Have a look to German constructions: Reliable, but heavy and not creative.
French: Creative, light, intelligent..... Compare German and french historic and modern weapons, or cars, or ships.....
So the construction of this little tank will be done like French, with a little bit of German security.
Remember the gas tanks we buy for camping, or lighters. their tank made of aluminium never is more than 0.5mm thick.
I will have made a calculation before construction. I like to survive for some years.
Andy
Re: gas container
« Reply #12 on: October 07, 2008, 09:07:00 AM »
Sorry Andy, I wasn't demeaning you, but in your previous post it looked like you hadn't understood our pounds per square inch.
I think you need to look at the German regulations concerning boiler and gas tank construction, you just might find the rules and regulations very similar to ours. Finding them is the major problem, but you must find out what is required by law.
I know that everyone thinks that they can make and run things as they please, but you might also find that not complying to the official specifications leaves you open to the full might of the law, also I would doubt if you would get the necessary insurance to operate an unqualified build from non standard materials. In which case, if an bad accident did happen, you would be on your own, with maybe a few million euros being stripped from your assets to pay for the damage to people and property.
You cannot quote in a court case that other gas can manufacturers only have thin casing, it is up to yourself to follow the rules, and produce a container that is made to recognised specifications. Maybe gas can manufacturers have a special licence to produce items that can easily blow the public apart, but I don't think you do.
I am not being sceptical or demeaning, just putting the facts into a straighforwards way for understanding.
You will do as you please, as it seems you are following your own route anyway, but by ignoring posts of a few concerned people, you are leaving yourself at the mercy of fate.
It will never happen!   How many times have you heard that before?   The Titanic rings a bell.
Offline andy
Re: gas container
« Reply #13 on: October 11, 2008, 07:25:13 AM »
Hi John,
these gas tanks of myDIESSEN model were calculated by an engineer for atomic plants according to the german laws, and boiler, too. NOW I take the same material dimensions and tank and boiler as well are about 2/3 of the diameter of the old ones. So securitiy means minimal 30% more. Believe, that I do not want to have an accident with the model, but I like to optimize my constructions.
In 1975 when I started to built the PS DIESSEN´s model engine, I also had to minimize weight, so this horizontal engine I made with a weight from about 1000grams. And it runs fine, is very stiff, but comarable model engines of this time had a weight of about 2500 grams. So I hade to decide if I could optimize weights without making a bad construction, or to have a submarine paddler.
So my decision always is to integrate optimal and creative constructions into my models to make them swim and move.
Is a similar job as my job as architect. Customer has no money, and I have to reach the goal with little money and good architecture. So I have to start my brain and not to waste materials.
Sorry!
And: I do not like laws, taxes........
Andreas
boilertester
Re: gas container
« Reply #14 on: December 17, 2008, 12:39:11 PM »
Hi Everyone
Only just found this topic, and the attitude of this member is quite disturbing and something I feel strongly about and the comments I make later need to be said. Nickel Silver is the only other material other then copper that can safety be used for amateur builders of gas tanks, commercial camping gas tanks are made of steel and the valves are probably made to blow out above a certain temperature and pressure, both steel and stainless steel (inox) have to be joined by coded welders but copper and Nickel silver can be silver soldered. the UTS of nickel silver 50000psi has opposed to coppers 31908psi so tanks of 20 swg could be used, 16 swg for copper, at present one British manufacturer uses nickel silver and has boiler tester we test them, though most of the small model marine boiler do not come under the boiler test codes they are done for insurance purposes.
Now far the serious bit!!
The blatant disregard for proper engineering practice in this regard will 'EFFECT US All' and it will only take one serious accident and we will all be banned from sailing our steam boats in public places, it has taken us years to get to the status quo we have at present and the stupid efforts of one or two individuals who obviously have no ideal of proper engineering practise and put aesthetics and creativity above common sense and safety will ruin it for us all.
GAS IS DANGEROUS IT CAN AND WILL KILL IF NOT TREATED WITH RESPECT
Paul R
Boilertester
PS
 I could have put this a lot stronger but this is a web site for all ages.
