Author Topic: BOILER SIZE  (Read 4015 times)
BOILER SIZE
« on: August 25, 2008, 08:21:48 PM »
Hi, can anybody please point me towards info either on the net or in books on how to work out what size boiler a particular engine needs? I have a Saito V4 which is currently hooked up to a Cheddar boiler, a Puffin I think, which is obviously not big enough as it will not maintain pressure at anything over half throttle. The Saito is 9mm bore by 10mm stroke by 4 cylinder which by my calculation makes it 2.52cc. I also have a 5/8 by 5/8" single (3.2cc) which needs a boiler. I presume there must be a formula which tells you how much surface area is needed to produce enough steam for a particular size of engine? Thanks, Ian.
Re: BOILER SIZE
« Reply #1 on: August 25, 2008, 10:37:02 PM »
Hi Ian,
Page 3 of the members submissions has an article by Malcom called " Matching engine, boiler and prop sizes"
Offline andy
Re: BOILER SIZE
« Reply #2 on: August 26, 2008, 01:20:08 AM »
Boiler:
As big as possible like the cubic inches of a Chevrolet.
And internal, heateed surface as wide as possible.
Andy
Re: BOILER SIZE
« Reply #3 on: August 26, 2008, 05:02:48 PM »
Hi PD's....Ian........Malcombeak provides some good reading in our downloads section under....as below
http://www.paddleducks.co.uk/index.php?ind=downloads&op=entry_view&iden=23
Sandy from ACS also posted quite a number of articles...again in our downloads.....
As a rule of thumb....it appears that the professional model engine/boiler manufactures have got it down to a reasonably fine art in that their package offerings will provide say 30 to 40 minutes steaming be their engines  of ....2 CC or 6CC....& then all of the extras...boiler feed pump...larger gas tank....gas regulators...computer boiler control & all or some of these are valid bits & pieces if you want & can afford them.....
One variation here....Monahan seem to have used  higher water capacity boilers for engine/boiler package :hammer  that the French manufacturers ....which is not a bad thing when comparing US$ to EURO.....Derek
« Last Edit: August 26, 2008, 07:21:39 PM by derekwarner_decoy »
