Other Marine Models
Live steam
New steam engines and locomotives
Topic: New steam engines and locomotives (Read 7125 times)
andy
July 16, 2008, 06:39:25 AM »
http://www.dlm-ag.ch/index2.htm
http://www.raddampfer-kaiser-wilhelm.de/verein/Mitgliederbericht/Montreux/Seite_3.htm
go surfing on this site, the DLM is a workshop, building new stam locomotives and restoring old ones. And they also developed and built the new steam engine of the Lake geneva paddler Montreux in 2000, which got this new engine when they gave the diesel electric engine to the waste. I think, that was the right way instead of doing reverse. But that´s possible only in the lucky Switzerland!
kind regards
Andy
Last Edit: July 16, 2008, 06:41:57 AM by andy
Re: New steam engines and locomotives
July 16, 2008, 04:36:44 PM »
Hi PD's & thanks Andy for the build snaps of the replacement Montreux steam engine
In snaps 17, 18 & 20.....we see a GRAY coloured device on the output shaft [right hand side in each view]...possibly 1.5 m diameter & 2.0 m tall
Is this part of the engine?
......it appears to have it's own lubrication tubing mounted?
?....or could be an external brake unit for load testing the engine?
....................Derek
Last Edit: July 16, 2008, 07:51:20 PM by derekwarner_decoy
andy
July 16, 2008, 09:48:55 PM »
if you could understand German, it was written in the several links of the report. This part is, as you supposed, a brake for testing the output of the engine. This had to be checked before the CGN paid the engine. What was this brake? Was the former transmission unit of the ship which had to work against the new engine! Torque of the engine was sufficient!
Andy
steamboatmodel
July 16, 2008, 11:24:43 PM »
I use Google Translate, and it works pretty well. I would love to be able to play with the Machining Center they used.
July 17, 2008, 08:27:09 PM »
OK PD's....
Gerald ....yes I do use Google translate......
Andy.....I have looked @ the DS revaporisiterte Montreux Foto 024 ....shaft couplings....but do not understand the locking external tubes on each end of each coupling bolt?
?.............Derek
andy
July 18, 2008, 03:00:00 AM »
Derek,
I cannot see what you mean? maybe too many smileys around the photo?
Andy
Dinosaursoupman
July 18, 2008, 11:41:56 PM »
Hello Andy,
Derek is refering to the flange where the crankshaft and the paddlewheel shaft meet. The six visible bolts per side (obviously there are more per side) seem to have an unusual bolt or nut that extends several inches from the flange on the paddlewheel side of the flange. You can see them clearer in the original photo on the website of the photo above, photo #24.
Randy
Last Edit: July 18, 2008, 11:45:12 PM by Dinosaursoupman
July 19, 2008, 08:38:17 AM »
Hi PD's &
Randy for the explanation.........
....I was deliberating in asking the question again as the more I looked @ foto 24....the less unsure I was........as the outboard tube caps appear to be on a larger PCD than the corresponding inboard bolt heads ...but this could be an optical illusion
If we can see six coupling bolts....my guess is a total of ten on each side
Foto 14 also displays a similar bolted arrangement between the three bigend support columns & the fabricated engine bed........Derek
Last Edit: July 19, 2008, 01:00:19 PM by derekwarner_decoy
July 20, 2008, 11:02:42 AM »
Hi PD's....in the Montreux preamble for the new engine...the following is noted.....
Design and construction .......Klassische, geschmiedete Kurbelwelle
Classic, forged crankshaft
Interestingly in one of the
video 200 80419_036 [provided by Andy]....the RH crank webs appear to be of different [fabricated?] construction and machined differently to the LH crank webs
......I use RH & LH as shown on the screen in the video as I do not know the orientation of the engine in the vessel
Anyway.....great videos & thanks Andy............assumed as another vessel in video 20080522_0160...we see the three engine pressure gauges & two are confirming the subtle pressure pulstaions of the engine....not sure if the center gauge is
...or could it be a condensor vacuum gauge?........Derek
Last Edit: July 20, 2008, 11:42:21 AM by derekwarner_decoy
andy
Reply #9 on:
July 21, 2008, 12:09:04 AM »
I cannot find this video- number!?
But I only have videos of the HOHENTWIEL- engine and of the URI engine. HOHENTWIEL is black painted, Uri red painted. Both are fitted in front of the paddle shaft, both are ESCHER WYSS engines.
The video with these gauges is from HOHENTWIEL. according th what the macne officer told me this are the pumps for the toilet water and behind the big one moving excenter is the vaccum pump- like shown to you in the photo of my model of the DIESSEN.
Andreas
Dinosaursoupman
Reply #10 on:
July 21, 2008, 12:54:33 AM »
Andy,
Let me once again translate for Derek
Derek is referring to video 200 80419-03
8
6. It shows the 2 crankshaft webs/throws in action. While the crank on the left in the video appears to be forged from a solid piece, the one on the right looks as if the crank pin/journal might be removable via the large nut on the left side of the pin. Do you know of the reason for such construction? Why the difference between the 2 pins? Repairs perhaps?
Randy
andy
Reply #11 on:
July 21, 2008, 02:30:09 AM »
I think, that tue crankshaft is divided with the bolt of the right pin, because there is a second piece with annother pin for moving the vaccum pump which cannot be seen on the right side. Was too long to produce??
Andy
Other Marine Models
Live steam
