Author Topic: 2CC.....V twin Oscillator Comparison  (Read 9683 times)
« on: June 13, 2008, 09:58:49 PM »
Hi PD's......a propellor type colleague.. :shoot :ranting. asked for a comment on an approx 2CC twin cylinder oscillator for his planned vessel...so  :thinking.. I looked at........
1) Anton 'Sapphire' V twin = 7 bore x 12 stroke =  290 EURO = $475 AUD
2) Monahan 'Cirrus' V twin = 8 bore x 11 stroke = 395 US $ = $422 AUD
3) Stuart 'Puffin' in line twin = 11 bore x 11 stoke = 415 UK pounds = $678 AUD
4) John Hemmens 'Richmond' V twin...assumed as 11 bore x 11 stoke = 260 UK pounds = $424 AUD
5) Regner 'Venus' V twin = 10 bore x 14 stroke = 189 Euro = $308 AUD
This cost comparison pleasently supprised me... the Monahan version has S/S sealed ball bearings in the big end...& is more engine like ...cylinder caps secured by hex head screws....plus conventional compression springs to support the valve plate to piston plate interface under pressure
The Anton Sapphire has the conventional big end pins running in the bronze bearing blocks and relies on O-rings as the "keep together" elements - I must question the serviceability or longevity of  O-rings in maintaining steam closure here
Most industrial ball & roller bearings have a unique reference of B10 ....you guessed it .... :hammer ten thousand hours life
[The typical rating for the life of a ball bearing is determined at the L10 or B10, where L (in English, L=life) or B (in German, B= “Brucheinleitzeit”), the life at which the initial crack appears in a ball bearing or as Fred Geitner says:
            Bruch = breakage/fracture,
            Einleit(ung) = initiation/introduction,
            Zeit = time or the fracture/breakage initiation period or incipient failure time/period.
Other common design percentage values for B or L are described in section 2.8 of The New Weibull Handbook, 5th edition, by Dr. Robert B. Abernethy, ISBN-13: 978-0-9653062-3-2 or ISBN-10: 0-9653062-3-2 which was published December 2006.  In short, L10 º B10]
.... :bravo...so based upon this the median cost of $422 AUD....& the only one to use S/S sealed ball bearings ....is way out in front for my choice
....... my recommendation is still the 'Cirrus' V twin engine  :no1b
 :oops...I just deleted the word nitrile...[for the O-rings].........it was just an asssumption.... :sorry
« Last Edit: June 15, 2008, 09:22:52 AM by derekwarner_decoy »
Monahan Steam Models Inc.
Re: 2CC.....V twin Oscillator Comparison
« Reply #1 on: June 14, 2008, 05:09:24 AM »
Thank you for your recommendation and positive feedback! Much appreciated! :beer
We are trying our best to keep costs down on these new engines, yet still be able offer the best quality we can for your investment.
With the new Sparrow engines and oscillator range, we are hoping to be able to offer a suitable paddler engine version of these if enough people can use them to make it cost effective to produce.
Thanks again :beer,
Nick
« Reply #2 on: June 14, 2008, 08:36:41 AM »
Of the 2 engines considered, I like the Monaham Cirrus better. Especially because the cylinders are round and look more "real".
Then there is also the Regner Venus V-twin oscillator:
http://www.regner-dampftechnik.de/aktuelles/neuheiten2007/venus_easyline.php
What I don't like with all three engines, is the price. I think it should be possible to make and sell simple oscillating engines like these for around 100 Euro.
I wonder what if Mr. Monaham could make a double cylinder engine in this price range.
« Reply #3 on: June 14, 2008, 11:46:05 AM »
Hi PD's...I have edited my previous posting to now compare [5] similar displacement oscillator type engines & my comments are self explanatory
kno3...I understand your comments on costs & we need look no further to the build by our own "bogstandard" ... called 'engine made from junk' [ :sorry John ...I know I have the incorrect title here]...where he produced a more complicated twin cylinder engine for ten EURO or less than 1/2 a case of  :beer
The real issue here is that manufacturers   :crash be they make TV sets or motor vehicles or model steam engines all need volume of manufacture to make a profit....second point is not all of our members have the necessary skill + knowledge + experience + machinary + time to produce such wonders  :clap :trophy - regards Derek
« Last Edit: June 14, 2008, 02:10:42 PM by derekwarner_decoy »
« Reply #4 on: June 14, 2008, 01:14:11 PM »
Hi Kno3,
That Regner engine is a pretty neat design! This is the first time I have seen one. What do they sell for?
Making a two cylinder oscillator for 100 Euro is possible but there will usually be sacrifices that will need to be made to the design to accomplish this. Manufacturers would definitely sell a lot more at that price.
Designing engines for production is always a tricky balance between form, function, etc..  Operating costs for a manufacturer are also a huge concern.
The Regner design for instance does not require any welding from what I can see. The main engine frame is primarily built up from machined plates which probably have the steam passage ways cut into them. This is a smart design because it will require less time to put each engine together and also not require any welding. Welding always adds more procedures and cost to each unit due to the need for fixtures, welding, cleaning, and then assembly. Oh and we must not forget the rejected parts that don't pass the welding procedure.  ::) :ranting
Form or general appearance is always major concern too. The more visually appealing an engine is, the more likely it is to have more components or trickier to produce components, which will also increase production costs. However this may not always be the case. Most of the smaller oscillators in this size range of these three engines typically have pressed in cylinder covers. This is one method of reducing overall costs.  A small problem with this method of sealing off the cylinders which may or may not concern most people is that there is not a easy way to service the piston or piston rings should they need servicing. Typically some engines with pressed in cylinder covers do not use O-rings at all for seals and will instead have small grooves cut around the outside diameter of the piston. These grooves provide a means for collecting oil or water which provides some sort of seal.
Painting can also become a huge undertaking thus increase the end cost. Painting one or two engines is not a problem. Painting a couple of hundred can make one wish for an earlier death especially if there are multiple components that require paint. The amount of prep work (masking off) for painting all these little parts can take up to months. Plating is a much more cost effective means of coating components especially when you think of the labor to profit ratio. However plating is not a traditional type of finish for most steam engines.
Part tolerances can also play a roll in increasing an engine's overall cost. Tighter fitting range of allowable tolerances for engine components can not only increase an engines life span but also its performance. A setback to this can be more parts being rejected and thrown away because they do not meet the stricter required dimensions.
Once you have found a good balance of design between engine performance, life span, overall looks, and a efficient way to produce the product you are left with the most important matter,.....price.
As expensive as these engines can be for consumers, there is almost always very little profit in them for the manufacturer. And even less when they sell to distributors. The smartest way to make up for this is to provide the best possible products at the best possible prices and focus more on volume verses trying to retire off of one or two engine sales. Further cost reductions can be accomplished by producing components in volume and these savings are ultimately reflected in the end price. Unfortunately the kind of volume needed to significantly reduce prices even further can not usually be achieved in such a niche market unless the work is farmed out over seas. So the production focus becomes more based on manufacturing efficiency. We run two shops. One is dedicated to Monahan Steam Models. The other to producing components for other industries. Our company uses some of the most advanced and efficient machining equipment available in the world to produce our models more accurately and more cost effectively. Luckily for us this equipment is used to produce items for other industries, as using this equipment alone for the production of steam engines would have bankrupted us years ago. In fact the fair market value we charge to manufacturer components for other industries on the same equipment typically nets us 3 times that of what we offer each component we make for our steam engine business. So not only does the steam engine market bare less return for labor but also less volume.
We run our company as a serious endeavor since we have huge investment in it, but in the end it is really just for the love of steam engines and getting to meet interesting people like all of you.
The simple answer, and probably what I should have left it at before boring you all is yes, we can produce an engine for 100 Euro but unfortunately it would not look like the Venus, Sapphire or the Cirrus.
Best Regards,
Nick Monahan
P.s. If any of you are in our neighborhood around October the 11 there will be a really great model boat show being held at the San Francisco Model Yacht Club's Lake. This is an bi-annual show and there is always a big turn out of Tugs, Paddlers, and Steamers!
« Reply #5 on: June 14, 2008, 08:14:50 PM »
OK PD's..... point of clarification here...........& the only one to use S/S sealed ball bearings ....
JMC  have used the same S/S ball bearing bottom end construction for years.... & which I have in my JMC 3H engine...... :bravo & best regards to you Jean Marc    :coffee....regards ....Derek
« Last Edit: June 14, 2008, 08:31:11 PM by derekwarner_decoy »
« Reply #6 on: June 14, 2008, 08:39:38 PM »
Hello Mr. Monahan,
To answer your question, the Regner Venus costs 189,00€ (as advertised on their website, where you get if you click the link in my previous message).
I have never had a Regner engine, so can't tell much about them, but they seem to be well made. It's a German company that makes a lot of very nice steam locomotives and other types of steam engines.
I have to agree that most of their marine engine don't look as beautiful as yours.
The discussion about the cost of making and selling steam engines is very interesting. However, I think it is better to have a separate topic. This one should remain for comparisons between V-twin oscillators.
I made the new topic about steam engine prices here:
http://www.paddleducks.co.uk/smf/index.php?topic=3519.0
