Author Topic: First "head of steam"  (Read 8301 times)
GreeboTheCat
« on: April 15, 2008, 08:58:53 PM »
 :goodnews :yeahbaby :great After 9 months gestation, my Alexandra Steamer finally vented its first puff of steam out of the funnel! I must say that there is a lot more satisfaction seeing it all work, more so than I ever got from plugging wires into sockets and connecting batteries to shiny motors that came ready assembled in a box. Mind you, I can see now what you guys have been stressing about keeping fingers off the machinery  :oops it does get damm hot! I didn't have the radio connected up for this first test so when I thought "try reverse now", I got a bit of a shock at how hot the reversing lever was...tssst! Got a few little niggles to sort out - for instance, there seems to be a lot of water coming out of the exhaust as if it's condensing too quickly. Any ideas?
Greebo
crash93
Re: First "head of steam"
« Reply #1 on: April 15, 2008, 09:03:31 PM »
Over the water out of the exhaust, are you over filling the boiler, and are you running it in to a condenser first, any pictures.
Peter
GreeboTheCat
« Reply #2 on: April 15, 2008, 09:51:44 PM »
I don't think I'm overfilling the boiler, only went 2/3 up the sight glass the first time. I am running into a condenser (see pictures) The water appears in the silicon tube immediately after the exhaust manifold - maybe I should be using lagged copper pipe into the condenser? or maybe I've boobed a bit and the condenser is too far from the manifold  >:(
crash93
« Reply #3 on: April 15, 2008, 10:05:43 PM »
I don't think you should have problems with the length of pipe or the lack of lagging. but just one question are you using the right outlet pipe on the condenser and not the one from the bottom for emptying it.?it just seems a bit strange that it is spitting water.  sorry for not being of help
peter
Offline Bierjunge
« Reply #4 on: April 15, 2008, 11:18:12 PM »
Congratulations, Greebo!
This seems to be a good week for Graham TVR1A engine test runs; out of a funny coincidence I did mine just two days ago (as shown in http://www.paddleducks.co.uk/smf/index.php?topic=3401.msg15144 ). In contrary to yours, I have unfortunately no finished boat yet.
Btw, I had no water spitting out of the exhaust at all although I run it on saturated steam as well, and have quite a long unlagged tube between condenser and funnel. No idea what's the problem at yours.
Regards, Moritz
sandy_ACS
« Reply #5 on: April 15, 2008, 11:24:08 PM »
 :) ;D ;D ;)
Hi PD's,
Grebo......  :great congratulations on the first firing.... a super model and very well built.... be proud of yourself. :no1b
As to your issues....... YES...IT DOES GET HOT.....around 140 degC...... just let it cool down a bit before you make the tea wiv the water...... overwise yer just burn the leaves..... :hehe :hehe...as for charred fingers.....welcome to the club. :no1b
From the pics I would say you have it all connected correctly, however, I would recommend that you fully lag (using white cotton string (British standard 1.5 mm - 2mm dia....none of this OZ lookalike stuff)) the steam feed pipe (all sections) between the boiler and the engine.... you have a fair bit of exposed copper there and this will partially condense the steam before it gets to the engine.
Second....get rid of the large length of copper pipe between the condenser outlet (top middle) and the funnel.... try rotating the funnel to bring the side entry directly above the condenser outlet, and connect straight up with a short a length of silicone tube.
I think this is the main culprit as the steam is almost at atmospheric pressure when it leaves the condenser and it doesn't take much to fully condense it out.  The large area of, unneccessary, copper tube will act like a heat sink and just make the clean steam fully condense...hence water spitting up the funnel.
I notice also that you appear to have lagged the condenser with wood strip....looks great, however, this does effect the performance of the condenser a bit in that it prevents the heat escaping from the condenser,,, which it should be able to do....uverwize it kan't kondense proper..... :oops :shhh :shoot :porkies
Thirdly..... add a length of silicone/ copper tube to the condenser drain tube (top outer) and plug the end whilst running... (it can just lay in the bottom of the model, alongside the boiler whilst sailing,  otherwise you will get a lot of unwanted oily water spurting out, all over your model, as the water/condensate builds up in the condenser.
Hope this gets things going a bit better for you.... remember though, you will always get some condensation when you first start up from cold....lots of large metal bits to heat up first..... ;D ;D
Have fun and keep us informed.
Best regards.
sandy. :vacation :sunglasses
GreeboTheCat
« Reply #6 on: April 16, 2008, 12:22:29 AM »
Thanks for your comments guys, lots of things for me to try. Next step is to get it all fired up in the test tank bath although I'll have to wait 'till the missus goes out, she's not to keen on having oily scum in her pristine white enamel. That's oily scum from the steam plant you understand, not me  :whistle
BTW Sandy, even the whistle worked first time, scared the living daylights out of the cat  :shhh
Also, the 2 pics I included earlier were a bit out of date in that most of the pipework has been lagged with good British string and then wrapped in plumbers PTFE tape. I find that PTFE tape (along with Gaffer tape) is what keeps the World functioning properly   :vacation
Offline Bierjunge
« Reply #7 on: April 16, 2008, 01:22:16 AM »
Why should it condense properly at all?
In my understanding, its purpose is more a mechanical trap for oil and water already condensed in the engine, than an actual condenser.
If it condenses too much steam, it could overflow (and then you get serious spitting...). Therefore I think insulating it wouldn't be a bad idea at all! So it stays warm and catches only the already existing droplets out of the exhaust steam.
In my own setup with selfmade (in my case unlagged) condenser, after evaportating one full boiler, I found only as little as 20 ml water and oil.
Why should I want to condense more steam? I like the plume out of the funnel...
« Reply #8 on: April 16, 2008, 04:13:35 PM »
Hi PD's....& Greebo..one of the main differences between the steam set by Moritz & yourself...is that the former has a steam isolation valve on the boiler discharge - so in this case the pre heat does not create a lot of soggy steam just prior to the steam regulator
In your case it appears that you have approx 80 mm of 1/8" OD copper tubing prior to the engine steam control valve & this will fill & condense & fill & condense until start up & hence your steam/water splutters  :sobbing :nono
I am sure the suggestions offered by PD members will assist...however if all else fails you could install an ACS.....90SSV-18 which is 90 degree steam stop valve for 1/8" OD tube for direct boiler top steam tapping mounting
Even with the boiler mounted valve......  :ranting ...you still need to exercise CAUTION with the valve handle wheel as they get to 152 degrees C
« Last Edit: April 16, 2008, 07:42:21 PM by derekwarner_decoy »
GreeboTheCat
« Reply #9 on: April 16, 2008, 05:49:07 PM »
Thanks Derek.  Where would we ALL be without your attention to detail  :respect
sandy_ACS
« Reply #10 on: April 16, 2008, 11:02:03 PM »
 :) :D ;D
Hi PD's,
Interesting observation DEREK, :respect and it may well have a small effect, however, don't forget that whilst isolated, then the whole steam feed from poiler to regulator will be cold, and when the steam is first turned on (via the stop valve) it will more than likely condense out and pass through to the engine.... yer can't win....not only that, but the engine itself will condense a fair amount of steam until it gets up to temperature.
GREBO.... I meant to tell you....CATS DON'T LIKE STEAM WHISTLES.... :P :P :oops :hehe :hehe.....
it might pay you, since your oiltrap/condenser is quite small (volume wise)...I think Derek has the same size also, so it may also apply...... is to warm up the engine with the oil trap disconnected (just be sure SWMBO aint around, especially if in the bathroom :shhh :shoot :porkies) this will prevent it filling up with start up condensate, which could also be part of your problem.
Once warmed up thoroughly, reconnect the condenser/oil trap and away you go. :great :clap
Moritz asks: -
Good question, however, the answer is not as straight forward as first appears…….
Agreed… the primary objective of the oil trap/condenser is to capture the waste steam oil and any water droplets, how this occurs is the issue……
First off… what we are talking about is NOT the CONDENSING of the steam, but rather the condensing of the fatty compounds contained within the steam oil, and the trapping of oil itself. SO we are not really talking about a steam condenser in the true sense of the word…..
Steam oil contains a compound of animal fats and other fatty materials in order that the oil can become more easily miscible with the water vapour (steam), which in turn makes the resulting emulsion spread more easily over the surface of the moving parts of the engine, carrying the oils molecules with it, thus giving a better, and more evenly distributed, lubrication layer.
These fatty compounds remain in vapour form at a temperature above about 110deg C (approx temperature of steam at around 6psig), therefore, in order to eliminate these from the exhaust steam the temperature if the steam must be reduced to below 110deg C, however, the water vapour (steam) will still be vapour, albeit quite wet.
The exhaust steam directly from the engine will be at a somewhat higher temperature.
The actual exhaust temperature (and pressure for that matter) will be determined by many factors of engine design, valve gear timing etc, and operational layout.
If you consider that, in the majority of small model engines, the actual amount of RESTRICTED EXPANSION inside the engine is quite low (probably no more than 20%) then the pressure at the exhaust port will only be around 20% lower than the inlet pressure.
E.G 40psi inlet pressure (141.5deg C) …32psi exhaust pressure (135deg C).
This exhaust steam is then met with a, shortish, length of small-bore pipe (between engine and OIL TRAP), which restricts its further expansion and in order to escape it’s velocity increases as it is forced through the pipe by the pressure behind it……
Suddenly the steam arrives at a large void area (the OIL TRAP CHAMBER) where it can more easily expand (UNRESTRICTED) to a lower pressure (not atmospheric…YET)…. Result, it slows down, its pressure drops, and some of the oil, and water, droplets can fall free from the stream….. but hold on a minute…..
UNRESTRICTED expansion has another side effect…… SUPERHEATING.
When steam, at a given pressure/temperature is suddenly allowed to expand ,down to the lower pressure within the condenser vessel, the result will be steam which is SUPERHEATED for the new, lower pressure.
This can make some of the water droplets carried over from the engine return to steam, and the fatty materials contained in the oil will become more vapourised.
The temperature rise is a direct result of the LATENT HEAT stored in the high pressure steam…. It must go somewhere, or do something……. The initial response is to increase the heat of the steam, relative to the new pressure (SUPERHEATED)……. The only way to overcome this is for the heat to be dissipated via the walls of the container……. HENCE LAGGING WILL interfere with this process.
Some may suggest that the OIL TRAP (condenser) is open to atmosphere, and hence no pressure can be involved……WRONG.
Whilst I agree that the oil trap/condenser is not a true pressure vessel (in as much as it is not a sealed container) it is in fact connected to the TRUE atmosphere by a length (variable) of pipe, which in turn (depending upon length and bore) will impose a restriction on the free expansion of the steam down to final atmospheric pressure, therefore, whilst in operation, the contents of the oil trap/condenser vessel will be at some pressure above that of the atmosphere.
If the pressure, in the vessel, can be reduced to below 5psi (steam temperature 108deg C) and the excess LATENT HEAT of expansion can be expelled via the walls of the vessel, then all should work just fine, the fatty part will condense out and only clean steam vapour will exit from the final outlet to atmosphere.
This is a tricky balancing act, and is very specific to each and every installation….. get the OIL TRAP/condenser vessel TO SMALL and the pressure and steam temperature will remain to high (heat exchange via vessel walls will be a much bigger problem, especially if lagged), and some of the fatty deposits will be expelled rather than condensed out and trapped.
Get the VESSEL to big and the exhaust steam can become far to superheated, which in turn will keep the fatty deposits in vapour form and again expelled with the steam unless the LATENT HEAT can be extracted via surface conduction.
Again, lagging will not help, but hinder.
Moritz….. I am very impressed with your steam plant layout and the trouble you have gone to in order to get it set up as closely as possible prior to installation.
I look forward to seeing the final build of the model.
From your description of your testing, and the residue recovered after on boiler full of water had been evaporated, (which on the face of it is a very remarkable achievement) I wonder, how much of the 20ml was actual oil? And how much oil went in to the engine from the lubricator?
I understand that it is difficult to be precise about the amount of recovered oil, however, if e.g.5 ml was the estimated recovery, and 6 ml was taken from the lubricator….. where has the remaining 1 ml gone…….. this could be the amount of fatty material lost with the steam via the funnel…… I.E not condensed out.
If, on the other hand, the recovered amount was exactly what was taken from the lubricator, then you have got the MAGIC balance, however, lagging the oil trap/condenser could actually ruin the results by interfering with the heat transfer.
I think you will agree, on balance, that perhaps it is better to over-condense a little, and be sure of getting all the oily deposits out, rather then under-condense, and allow some fatty/oil deposits to escape into the surrounding environment.
After all, it is no big hardship to stop and empty the condenser at suitable intervals, and if you don't use automatic boiler water level control, you will need to stop and re-fill the boiler anyway, and possibly the gas supply tank,...so why not empty the condenser whilst waiting for pressure to come back up again.
One thing is for sure..... this is a tricky and fascinating subject, and not one there are always easy answers to.
Ok, enough already!!
Keep steaming,
Best regards.
Sandy
 :vacation :sunglasses :beer :breakcomp
« Last Edit: April 16, 2008, 11:07:02 PM by sandy_ACS »
« Reply #11 on: April 17, 2008, 05:12:53 PM »
Hi PD's.....& Greebo says
thanks Derek.  Where would we ALL be without your attention to detail
But in reality is again Sandy who comes back with comments, thought provoking questions, & potential answers  :bravo I'll have a :beer for you on the strength of that lot of  :spam  :nahnah
Seriously though....this is a vexing question...Moritz does not have the splutter issue....Greebo does.....they both use the same engine...but every other component is different
Certainly in my case I have ~~~~ 450 gms of cold brass that will attempt to condense the steam prior to discharge from the engine
 :squareone...Derek
GreeboTheCat
Re: Second "head of steam"
« Reply #12 on: April 17, 2008, 11:07:54 PM »
The missus was out today so I sneaked into the bathroom and did a proper "floating with propeller load" steam up and the results were very encouraging. I have expedited all your tips and advice (apart from ripping the lagging off the condenser) and guess what... no more water/steam spluttering  :terrific Once everything gets warmed up she was rarin to go and when I had run a full boiler through the condenser had about 10ml of oil emulsion to empty out so the oiler is definitely doing it's job and this is borne out by the fact that the engine is freeing up nicely. A couple more dry runs and I am encouraged to "get it on the pond".
« Reply #13 on: April 18, 2008, 05:00:25 PM »
OK  PD's & good to hear Greebo that all is fine in the anti splutter department......just a little of topic..... :crash..how is the stability/balance of the vessel in the water [ :sorry...in the bath tub when Mrs Greebo is out shopping].... :oops :hehe
GreeboTheCat
« Reply #14 on: April 18, 2008, 06:12:15 PM »
Stability is fine . . .now... but when I first floated her in the test tank bath she floated very high in the water (bit like a plastic duck!) and was in danger of tipping at the slightest wavelet so I drilled a couple of holes in the deck (under the engine plate) and poured in about a kilo of lead shavings followed by epoxy resin to hold everything steady. Incidentally this procedure was also carried out in the bath to make sure the heat produced by the curing epoxy didn't affect the hull.  :shhh This did the trick and she floats perfectly now but it was a bit of a worry at first with such a narrow beam and with a heavy vertical boiler.
