Author Topic: Multiple Pictures  (Read 2837 times)
Offline Bunkerbarge
Multiple Pictures
« on: October 13, 2007, 02:36:58 AM »
Could someone please tell me how to attach more than one picture to a posting.
Thanks
“Dirty British coaster with a salt-caked smoke stack, Butting through the Channel in the mad March days"
Re: Multiple Pictures
« Reply #1 on: October 13, 2007, 04:39:08 AM »
Quote from: "Bunkerbarge"
Thanks
It's easy, when you post a message, you will see the file attachment box at the bottom of the posting window, click on "Browse" to locate the photo on your computer, enter a description if you wish, then click on "Add Attachment" - If you want to add a second image simply repeat the procedure, a new File Attachment box will appear as soon as you've "Added" an image.....
One you have added all the images you want, and you've typed in your message, just click on "Submit" to finally post it onto the forum.
Images MUST be kept to a reasonable size, try to keep them below 200kb each, or our hosts server can run out of memory processing them.
It's easier to do than to explain, give it a try and you'll see it's pretty straightforward...
