Author Topic: Various - small talk only  (Read 4864 times)
« on: July 21, 2007, 01:11:06 PM »
Hi PD's - I posted a few messages to Sandy & John which will be self explanatory....................a certain number of PD members have questioned  :ohno why it has taken 7 years to get to this stage with my build of PS Decoy.....anyway things are now progressing with the removal of No 9 hull frame....
I have wasted one year & countless one foot lengths of 1/8” & 5/32” tubing in trying to maintain the bulkhead – the designer/engineer should be sacked….but who then would finish the project??????????????...........
I have added a few snaps in Decoys folder & will do so as the build progresses.....& yes  according to MS Project calculations via the :computer ... PS Decoy should be on the water on 14/3/2101 :hehe - Derek
Morning John....I hope this message finds you well with Bandit doing his sums & cat painting as usual.......it is Saturday  here in OZ but I must do some internal sanding  on PS Decoy where No 9 bulkhead once resided & then maybe one  ...................regards Derek.........................................................................................................
From: Derek L Warner Pty Ltd [mailto:dlwarner@bigpond.net.au]
Sent: Saturday, 21 July 2007 10:07 AM
To: ACS Engineering
Subject: Various
Hi Sandy….hope Kate is happy with the new galley cupboards…
a) thanks for the tip on CupAlloys 42% Ag…..have ordered as below… the Comsol is fine, however my ANTON manufactured gas regulator….????... yes with o-ring sealing for 2.0 mm OD tube, but the construction is not tube captive so I need a composite temperature form of construction
b) have removed that problematical number 9 hull frame bulkhead from PS Decoy & now will rebuild the boiler & engine on one common base plate…………….I have wasted one year & countless one foot lengths of 1/8” & 5/32” tubing in trying to maintain the bulkhead – the designer/engineer should be sacked….but who then would finish the project??????????????........... I will post a snap on PD’s this weekend
c) from his comments, I know John [bogstandard] enjoyed his engine build & reporting on PD’s immensely… a very talented person [I love his droll sense of humor/wit] & I certainly have taken onboard his advice & comments on silver soldering issue
d) the end of June 2007 is gone………when will you revise your ACS WEB site???????????????????
Best regards ………….Derek
« Reply #1 on: August 05, 2007, 10:33:40 AM »
Hi PD's.....just a few weeks ago I suggested that John's bent axis INFERNAL  rotating machine was made from ''''the baking dish''''..but  :nono &  John responded.......NO but part of the washing machine :idea:
So with the need to mix small quantities of epoxy BOG  :hammer to repair the damage caused by the removal of number 9 hull frame.....I found the  :no1 container
 :great the teflon coated cookie tray  :terrific but  :ohno  :shhh...I cannot remove  :crash the epoxy BOG  from the cookie container....
I never liked cookies anyway :nah
PS.......as I type  :computer ...the epoxy BOG is curing the mounting feet for PS Decoys combined boiler & engine base..... :music
« Reply #2 on: August 05, 2007, 10:35:52 AM »
OK.......here is the cookie tray
« Reply #3 on: August 05, 2007, 04:17:30 PM »
What a plonker, I bet her indoors just loves you. :darn
Your cookies will taste horrid for weeks to come, mind you with all that garlic you most probably wouldn't notice.
I used to buy the smallest plastic flowerpot drip stands in bulk, about 2" (50mm) in diameter. I used them for mixing all my paints and epoxies. Fairly easily cleaned, but when really grotty just thrown away. Costs only a few pennies each (a lot cheaper than cookie trays) and a hundred lasted me for years.
By the way have included a couple of pics, this is where Bandit and myself live. Compact and bijou. :vacat
« Reply #4 on: August 05, 2007, 08:09:32 PM »
Hullo PD's....& what do I see in the ....'machinary....and,,,jpg'  :rant
Just down from the Cup of  :coffee is a bloody veriner caliper with a TV display for dimensions
I can only assume that this is for a 'back  :crash check....of dimensions  by Bandit ' :hehe
crash93
« Reply #5 on: August 06, 2007, 08:46:45 AM »
I tend to use these I know some people use old tubs and such  but I am always fearful of contamination , and these are cheap
Peter
« Reply #6 on: August 06, 2007, 03:39:16 PM »
Whats wrong Derek, are you jealous or what of my digital calipers, I suppose you are still using a knotted string for all your measurements.
The Aussies don't rate them because they think they are mini tv's built into a precision adjustable spanner and can't fathom out why it won't pick up Neighbours. Read this next bit very very slowly - YOU NEED TO CONNECT IT TO AN AERIAL.
That will keep him busy for weeks.
Don't tell him too much Peter, one bit of information a day is enough, don't want him going into overload. Good idea by the way.
« Reply #7 on: August 06, 2007, 07:21:14 PM »
Hi PD's & goodness  :roll:
a)  :news yes we still have calibrated string in OZ ......quite accurate actually :nah
b)  :crash we also have coat hangers that we PLUG into our digital display adjustable spanners in an attempt to improve the screen clarity  :boom
c) no self respecting OZ member would watch that :offtopic  CRAP "Neighbours" .... as we are too busy watching ten year old repeats of the cop shop show "The Bill"  :clap .... Reg is still there after 20 years  :hehe
« Reply #8 on: August 06, 2007, 07:55:05 PM »
We now see where you are going wrong, Bandit says that the string is too thick and the knots are 0.006" oversize.
I also notice that you are using the Mikimoto grade of coathanger, and it should be the commercially available ones from Marks and Spencers, you know the ones, no colours and bare metal, no wonder you are having so much trouble :angel
To get back on the straight and narrow, digital verniers are now that cheap at about £8 (2 squillion $Aus) its not even worth replacing the batteries. I just pick up a couple every now and then when the boss drags me out shopping.
« Reply #9 on: August 06, 2007, 08:01:56 PM »
The doorbell just rang, so I went to see who was there..... I was greeted by a man dressed in a white coat who said he had received a phonecall from a concerned member of Paddleducks, and he needed Johns address urgently - Seems it was a dire emergency!
He also mumbled something about having to hurredly arrange a busmans holiday to Australia as there was another urgent case that required his attention......
« Reply #10 on: August 06, 2007, 08:45:09 PM »
All good for a laughF Pd's........ ........................................................................................................................................ :arrow:  :hehe  :music  :nah
« Reply #11 on: August 06, 2007, 09:05:48 PM »
What's a doorbell?
Screwy Louie
crash93
« Reply #12 on: August 06, 2007, 10:06:00 PM »
So why do we have to have episodes of BLUEY with Luck Grills and Boney??  we send our good crap and look what we get back!!
Peter
