Author Topic: Resizing Images before uploading  (Read 17464 times)
« on: January 17, 2007, 09:38:33 PM »
To make your photo images quicker to upload, and to save us webspace, the following instructions should help if your a WinXP user...
My sincere thanks to Martin at ModelBoatMayhem for allowing me to use his article. http://www.modelboatmayhem.co.uk/
First you may need to download the Windows XP 'Power Toy'  Image Resizer - http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
1. Open  Windows Explorer.   ( Windows key + E  or Right click my Computer > Explorer or  START > All Programs >  Accessories > Windows Explorer )
« Last Edit: March 20, 2008, 07:36:50 PM by Eddy Matthews »
paddlesteamerman1
« Reply #1 on: March 20, 2007, 06:19:30 PM »
Eddy,
I'm trying to resize a photo to upload as my avatar.. but I cant find the resize selection in the menu after highlighting the photo.
« Reply #2 on: March 21, 2007, 06:06:22 AM »
You can also resize using 'paint' (start/programs/accessories/paint) Open the image in paint and click on Image/stretch-skew then alter the figure in both 'horizontal' and 'vertical' fields in stretch area of the tool control to (for example) 20% of original (this depends on the size of the original picture and the size needed for an avatar) Then click 'File/Save As' (not 'Save' which will change the original forever!) Finally, exit paint. If it asks if you want to save changes to ****.jpg (the original), select no!
Or to be on the safe side, make a copy from the original first (save as) the open the copy and resize it.
paddlesteamerman1
« Reply #3 on: March 21, 2007, 08:07:55 AM »
Typical 'Me' Thing to do... I went into paint - and searched and searched.. and couldn't find it.. but I remember now seeing stretch-skew...
I will try resizing with paint now
GreeboTheCat
Too many Bytes
« Reply #4 on: September 20, 2007, 11:17:57 PM »
Got the re-sizing sorted but my intended Avatar image is still a bit too big. Max size is 6Kb and my (very small) image is still 10Kb. Is there an easy way to get down to 6Kb?
Greebo
« Reply #5 on: September 21, 2007, 04:27:31 AM »
.bmp is biggest (in bytes, kb) .jpg is usually much smaller but equally good quality.
as an example, the images below are identical but one is saved as a .jpg and the other as a .bmp....
*OK, looks like the .bmp doesn't display but has to be downloaded, but it does look the same and you can see the difference in file size!
Walter Cooper
« Reply #6 on: September 21, 2007, 06:52:10 AM »
Hello Greebo TheCat,here is a site that I use for resizing photos.It pretty good,plus its free! Walter http://www.stormdance.net/software/photorazor/software%20overview.htm
GreeboTheCat <forum@paddleducks.co.uk> wrote:
Greebo
 Post generated using Mail2Forum
GreeboTheCat
Photo re-sizing
« Reply #7 on: September 21, 2007, 05:49:08 PM »
Thanks fellas.
Greebo
