Large Paddler Builds
Power (Large)
little steam engine
Topic: little steam engine (Read 21342 times)
anth
little steam engine
November 16, 2006, 04:07:43 PM »
here is my little steam engine nearly finished except for a few fittings yet to be made.
specs
bore 2.1/2" with a stroke of 2"
double acting slide valve
slip eccentric valve timing with 75% cut off
height 19"
width 6"
weight 20kg
hp 1-1.5 depending on rpm and boiler pressure.
This engine was run on display at the local engineering tafe,it ran very smoothly considering everything is still wearing in.
The engine is yet to run on steam and will run even better due to the expansion property of steam.. :wink:
so for now it sit's in the corner of the lounge room!
cheers Anthony
paddlesteamerman1
little steam engine
November 16, 2006, 06:59:13 PM »
That looks brilliant Anth, I wish I could make one (I am not even going to try!!!!)
It is about the size I was looking for, but I think I might need a little bigger now, not sure!?!?!
Good Work
anth
little steam engine
November 16, 2006, 10:37:27 PM »
No you wouldn't need any bigger.....!!!
it would suit a hull of around 16ft,a engine a little smaller or reduced boiler pressure would be better.
cheers anthony
paddlesteamerman1
little steam engine
November 17, 2006, 06:40:12 AM »
No bigger then!! How much has that one cost you to make? And how heavy is it with a full boiler?
It still looks awesome
thewharfonline
little steam engine
November 17, 2006, 05:11:15 PM »
Is that the same engine you've posted before? It looks like you've painted it...have you?
I'll have to come and check it out some time! It will be good to see it under steam...I assume you ran it under an air compressor!
Sean
anth
little steam engine
November 17, 2006, 11:20:38 PM »
yes the same engine painted and all the brass wear added,it runs on compressed air for the minute,I am in the middle of making another but smaller.......
: can't help my self.
james the cost depends upon materials,and your own time!
I machine these engines from solid cast iron saves money in casting's but you spend more time...it's a trade off one for the other!
Sean your welcome to drop in with your grandfarther during the school holidays in another cpl of weeks :wink:
This will allow me to sort a few task's out of the way and tidy the workshop... :twisted:
and perhaps even make a start on the paddler boiler and engine.
cheers anthony
thewharfonline
little steam engine
November 18, 2006, 11:05:10 AM »
Oh sweet Anthony I will take up that offer...I still have a few weeks of school left and some play rehearsals coming up (about 4 weeks possibly...hope that gives you enough time) then I will talk to my grandpa about coming down!
Hopefully you will be able to talk him out of 'let's just try this' approach...trial and error garbage lol!
Can't wait to come and see your stuff!
Hey do you get your metal from Menzies Scrap metal or where do you get it from?
paulnb57
Re: little steam engine
September 16, 2008, 05:57:33 AM »
This is the type/style/size Id like to build - are there plans available please?
Paul
anth
September 16, 2008, 04:32:26 PM »
G'day this little engine was scratch built and designed by myself,it has no plans,it is a large engine not suitable for models,but is up to the task of a serious large size paddler of around 20ft....
hope this help
cheers Anthony
paulnb57
Reply #9 on:
September 17, 2008, 05:22:38 AM »
Thanks for the reply Anth - I relised this was full size rather than model, but Id like to build something similar..............
Paul
anth
Reply #10 on:
September 20, 2008, 07:04:53 PM »
where about's are you located...?
Do you have a machine shop...?
cheers Anthony
paulnb57
Reply #11 on:
September 22, 2008, 03:40:12 AM »
Isle of Wight UK and Yes
Paul
ronan
Reply #12 on:
April 11, 2009, 08:41:53 AM »
if any plans are available ,i'd be very interested in them , it looks nice and simple , have you a boiler to power it ?
Power (Large)
little steam engine
