Author Topic: Paddlewheels  (Read 21139 times)
paddlesteamerman1
Paddlewheels
« on: November 07, 2006, 07:27:55 AM »
Hello Mick,
This is just the post  :clap2  I have been looking for, I have been  :thinking about what paddle wheels I could use for my boat and by far your's look the best  :no1
Those paddle wheels are meant for models aren't they? Just by looking at your website. I was wondering if it is possible to follow the same method, but for a paddler that is going to be around 9-10m long? And what materials are best suited for a light weight durable paddle wheel? But your paddle wheels look absolutely awesome, and I really want mine to look the same, so hopefully I can build a larger version. Thanks heaps.  :beer
Paddlewheels
« Reply #1 on: November 07, 2006, 10:28:21 AM »
Quote from: "paddlesteamerman1"
Hello Mick,
This is just the post I have been looking for, I have been  :thinking about what paddle wheels I could use for my boat and by far your's look the best....
thanks....but for a 10 metre boat (ie. a real one???)
This is something I've thought about - though I doubt I'll ever get to put it into practice - and I suppose it should be possible to build them in a similar way but using steel bar of the type used for equipment racking in telephone exchanges! (I used to work in one years ago - even then I was looking at objects from the point of view of how they could be used.....) Not the racking itself, which was heavy angle-iron, but the steel 'tie-bars' connecting the racks together. It was about inch-and-a-half wide by quarter-inch thick steel and could have been bolted into the shapes used to form the wheel frame.....However, I now think I'd consider using 'cable drum' frames, which were available up to about 5 feet in outer diameter and welded construction, like this.... http://www.bryant-broadcast.co.uk/iqs/sid.01758940869515703102264/dbitemid.387/sfa.view/cable_drums.html ...expensive though so I'd be looking in scrapyards!
paddlesteamerman1
Paddlewheels
« Reply #2 on: November 07, 2006, 04:20:02 PM »
Thanks Mick! I will go and look at the site. Because I was thinking that if I could find a cylinder, and just take the two rims off it and use them as frames. But I will wait a bit and have a good look around..
thewharfonline
Paddlewheels
« Reply #3 on: November 08, 2006, 09:37:42 AM »
I've looked into this for my boat and I don't think it's a good way to go!
It can be hard to find two the same size, especially through scrap places, the wooden one's aren't the best wood and I think they would fall apart easily. They are also pretty heavy.
The other thing I looked into was 'wire drum' frames, much smaller and often metal, for the wheel hubs. Again this was dodgy...the metal bends very easily and with the applied pressure of the water I think you'd lose their shape pretty quickly.
We'll be making 'simple spiderweb wheels' for Grebe, but welding pieces together instead of plastic cementing! This has appeared to be the best form available for a small boat after I've spent a year looking for things that could work...including bicycle wheels! So Mick you'll be seeing much larger 'spidey' wheels soon. When the hull is finished we're gonna weld a quick wheel together and start doing engine trials!
paddlesteamerman1
Paddlewheels
« Reply #4 on: November 08, 2006, 10:55:54 AM »
Yes I have decided that I will be using the Simple Spiderweb Wheels for the Sarah Jane as well... I think it is the way to go.
paddlesteamerman1
Paddlewheels
« Reply #5 on: November 16, 2006, 08:27:40 PM »
Right, now I have a hull (that needs a bit of work but....)!
It is 14' long, 5'7''wide at the widest point and 2'6'' deep. If I was going by the rule of thumb that Anth pointed out, the floats would be about 10'' wide (rough guess made from my mind) and going by the SWPV Rusty, 5.2m long, I would go for around about 4' in diameter? Is that to big or small or otherwise??
Any help whatsoever is appreciated here!!
paddlesteamerman1
Paddlewheels
« Reply #6 on: November 20, 2006, 07:12:10 AM »
Sean, what are you making the Grebe's paddles out of?
I was thinking something very light weight but strong, nothing comes to mind that fits both catogories,
But the SJ is going to become a MV before a PS, so I will have some time to get the paddles together!
I am going to make balsa wood full scale models of the paddles, paddle housing before I get the real thing happening
thewharfonline
Paddlewheels
« Reply #7 on: November 20, 2006, 05:12:42 PM »
Wouldn't have a clue yet, I'm nowhere near ready for wheels yet. Engine comes first as that will determine wheel size etc etc etc
paddlesteamerman1
Paddlewheels
« Reply #8 on: November 20, 2006, 05:28:22 PM »
So the engines determine wheel size? I thought it was the size of the boat...
I am not even ready to think about any of that yet...... got lots and lots of work to do first!
thewharfonline
Paddlewheels
« Reply #9 on: November 20, 2006, 05:40:00 PM »
That's part of it too!
You've got to determine how large and heavy the boat is etc to work out the engine size needed which goes into paddlewheel construction as well!
It's all interwoven and obviously when worked out the best will create a better boat.
I feel sorry for William Randell who didn't have paddleducks to help him make the May Ann.
paddlesteamerman1
Paddlewheels
« Reply #10 on: November 20, 2006, 05:43:17 PM »
Yes, it is all interwoven, and everything counts for something!!
And William Randell would have had it tough, but he obviously did alright eh??
And you plan on using the simple spiderweb wheels right?
Do you reckon your's will be the circular or octagonal version?
I am thinking octagonal for the SJ
paddlesteamerman1
Paddlewheels
« Reply #11 on: November 26, 2006, 04:32:24 PM »
Just an idea put forth to me by Roderick..
If I were going to use the motorbike engine, I could use the to wheel rims as the base for my paddles, just welding on the floats and what not!!
I cant see why it wouldnt work..
