Author Topic: Steam Whistle for real padler!  (Read 11725 times)
thewharfonline
« on: December 01, 2005, 11:38:45 AM »
Ok heres a question for you...
I have my real paddler...(well it's getting theere) and I want  it to have a steam whistle...however she's not going tro be a steam driven boat so how do I get the whistle do work.
Could I use one of those little steam engine models or should I hook up an air compressor?
And then where do I get it from?
Any help is appreciated!
Thanks
Sean
« Reply #1 on: December 01, 2005, 04:51:21 PM »
Hi PD's - Sean - I guess the air compressor would work & you can get the 12V versions from Auto Parts shops [in OZ, Repco - Super Cheap Autos etc] for about $30.00 AUD, but they are very hungry in current draw :rant - & the noise level may drown out the whistle sound  :music - another option would be a SOUND UNIT - I am sure there have been some PD postings on good versions & not so great versions - Derek
Barrie
« Reply #2 on: December 01, 2005, 09:37:16 PM »
The obvious source (if you were in the UK) would be JJC - see references elsewhere on this forum. Plenty of volume, low current requirements - 6 or 12 volt SLA would be adequate - but it might be expensive to get it to OZ. Don't know about import duty etc. There are samples on http://www.jjc-electronics.com but I don't think they do the actual sounds justice.
Barrie
thewharfonline
« Reply #3 on: December 02, 2005, 11:13:37 AM »
Thanks for your replies guys and yes Derek I thought it might drown it out too. Thats why I was wondering if maybe the model boiler would work.....but I was researching steam whisatles and they need between 70 and 150 PSI can you do that on a model boiler?
« Reply #4 on: December 03, 2005, 01:48:19 AM »
Hi Sean,
If you check I think you will find it is not the pressure you need but the volume of air/steam look up Helmholtz resonator whistle, that should put you on the right track.
thewharfonline
« Reply #5 on: December 03, 2005, 11:06:09 AM »
Quote from: "steamboatmodel"
Hi Sean,
Thanks for that but on most of the steam whistle websites I've been on they've given a PSI level for runnind and I know from work experience that the whistles need so much pressure as well!
Such as the Adelaide's Big Boy Locomotive whistle! Why does the Adelaide have a Big Boy Whistle....who knows...I don't think anybody does!
ijig
boat whistle
« Reply #6 on: December 15, 2005, 09:38:05 AM »
I just built one for a friend of mine. He ordered a 12v compressor from harbor freight and came up with a lever valve. I built a whistle out of PVC Pipe and used an old 20# propane tank for air storage. I worked fine on his houseboat.
ijig
steam whistle
« Reply #8 on: December 16, 2005, 07:03:01 AM »
either one should?? work. the only way you will know is to try. 71GBP sounds like alot to me. PVC one can be built for uner $5 US.
« Reply #9 on: December 18, 2005, 07:02:49 AM »
That's true, I think the sellers of those two whistles might be thinking of them as collectors items (I don't know anything about restoring steam engines/traction engines so maybe that's just what they usually cost!) If using compressed air instead of hot steam, a PVC one should be good enough (then again, maybe if we were using steam it'd be possible to make one from a length of copper pipe of the type used in heating systems....)  :D
thewharfonline
« Reply #10 on: December 18, 2005, 03:01:17 PM »
so your saying I should make my own! I thought I nice old fashioned steam whistle would be nice! Maybe I could ask one of the guys up at Echuca about one...the guy I'm thinking of restors the engines so maybe just maybe theres something!
