Author Topic: PS Bunyip - Construction of a centre wheeler  (Read 3765 times)
lner
« on: October 14, 2005, 10:36:31 AM »
I have just completed my drawings of the PS Bunyip. They are only rough sketches and there was quite a bit of extrapolation involved.
Some of the dimensions proved very elusive,  and in the end the height above waterline and draft had to be guessed and redrawn several times to get the proportions right. (Trial and Error - emphasis on the error)
I have only found two images of this ship so far, but I am fairly happy with the end result.  I am going to begin work on the twin hulls shortly.  The initial plan is to produce a static model with a solid hull, but I may attempt a working model depending on the results.
The scale is probably going to be 1:36 giving an overall length of the model of approx 35".
The completed drawings are 1:122. On 5mm ruled graph paper this gives me one 5mm square for every two feet.
towboatjoe
« Reply #1 on: October 14, 2005, 10:49:41 AM »
I read an article in the Waterways Journal about the Bootjack Ferry Denver. If it's anything like your vessel maybe this will give a little help.
towboatjoe
« Reply #2 on: October 14, 2005, 11:06:05 AM »
Here's a photo of the Alex Baldwin and postcard of Leo Bisso. Both are center wheeled ferries. Here's a drawing that I started from a sketch.
lner
« Reply #3 on: October 14, 2005, 11:46:02 AM »
Thanks but I think I am beyond help!!!! :lol:
The Bunyip is a genuine twin hulled steamer with a huge floating storeoom built across both hulls.  I will post the sketches once I have tidied them up a little.
Your drawing is not dissimilar to the layout of the Bunyip
towboatjoe
« Reply #4 on: October 14, 2005, 01:24:33 PM »
Great, I'm looking forward to seeing them. Can't wait to see photos of the model when you get started.
