Author Topic: Help with Vintage Futaba FP-T6DN  (Read 4594 times)
« on: March 14, 2014, 10:25:53 PM »
Can anyone help with the Rx battery wiring it has 3 wires red black and blue original  with a Futaba FP-T6DN set circa early '70's with 5 wires on the servos It's a 27 Mhz set converted to 29Mhz
I pulled the old gear from my Schooner to find 4 ruptured NiCad's and nothing left of the wiring I  assume  it's
+2.4=red-----  neg=black----  -2.4=blue.
I'm averse to just trying it in case I damage this vintage 6ch Rx.
I thought I'd taken the batteries out when it last sailed 15 to 20 years ago oooops.
Re: Help with Vintage Futaba FP-T6DN
« Reply #1 on: March 22, 2014, 10:28:32 PM »
Solved.
Offline Brian Gates
« Reply #2 on: March 22, 2014, 10:52:29 PM »
Good news, but don't just say "solved" and leave us in suspense :)
I guess a lot of us tried a whole range of search terms on the web (although from the few hits I got, either nobody else has a problem or not many survived into the internet age), and somebody in future may search for the same thing and come upon this thread as their last hope.
So go on then, what are the wiring connections?
Brian Gates
Gillingham
« Reply #3 on: March 29, 2014, 11:24:13 AM »
Ok I soaked the old battery tray in a Bi-carb water bath for several days and though not perfectly clean it was good enough to determine  where the 3 wires were attached plus the links, it's certainly different to a standard 4 cell wiring
Here's a pic of the layout.
I had black wire syndrome so all wire and the 7 pin plug were replaced.
I once made a living from electronics repair but acquired brain injury after radiation treatment for a tumor wipe that part of my memory.
I also found NiMh batteries are a little bigger in diameter than standard AA cells and don't fit the battery boxes.
With a Dremel sanding tube and a scapel the NiMh batteries fit now.
« Last Edit: March 29, 2014, 04:30:58 PM by DamienG »
« Reply #4 on: March 29, 2014, 02:19:49 PM »
This is the reason I'm wanting the old Futaba working again.
Bought at same time early '70's
« Last Edit: March 30, 2014, 11:53:26 AM by DamienG »
Harold H. Duncan
« Reply #5 on: March 29, 2014, 02:31:27 PM »
Damien,
That's one loverly boat you have there.
Can now see why you want it all original.
beautiful
kiwi
« Reply #6 on: March 29, 2014, 04:25:25 PM »
Yeah, thanks Kiwi
Offline Brian Gates
« Reply #7 on: March 29, 2014, 07:09:42 PM »
We just don't realise how easy we have it with BEC and 24 Mhz do we?
« Reply #8 on: April 06, 2014, 08:48:57 PM »
That's for sure Brian.
